2 members (66flea, Bucker), 81 guests, and 4 robots.
Topics128,265
Posts1,058,363
Members48,485
#1333382 11/11/2019 10:05 PM
Since I took a job in central Nebraska, I took a liking to all these old farm/grain trucks. I spent some time and finally decided the 1941-46 was the one for me. Lucky me I found one in an old warehouse downtown David City, made an offer and Bingo! The only rust on the whole thing is in the wiper header where the mice built a nest and peed. Here are a few before and after a trip to the car wash.
Pat
1946 PW Grain truck, 1966 C10 long stepside, 1972 C20 Custom Camper Big Block, 1975 C10 Silverado OE big block.
Playher #1333384 11/11/2019 10:16 PM
She’s mighty purddy!😁
Playher #1333386 11/11/2019 10:32 PM
Crusing in the Passing Lane
Remove fuel lines, etc., clean them out, clean out fuel tank so antique fuel doesn't get sucked into fuel system, remove valve cover, push down gently on valves while oiling stem to make sure they are not stuck. Clean out all brake lines, get master and wheel cyl. kits or new cylinders.
Drive it.
Ed
Playher #1333393 11/11/2019 11:12 PM
Oops. I put a new battery in it, poured some gas in the carb and fired it...
Good news is, it seams to run good.
Pat
Playher #1333414 11/12/2019 12:52 AM
It belongs on a movie set....nice!
Playher #1333417 11/12/2019 12:57 AM
Apache1, I agree. I think the relatively small cab combined with the big fenders and giant tires makes this the coolest looking truck ever.
Playher #1333418 11/12/2019 12:59 AM
Gorgeous ride!
Playher #1333422 11/12/2019 1:34 AM
Wow , awesome. I guess I always look in the wrong places. lol
Playher #1333426 11/12/2019 2:03 AM
Cool just ad soap and water
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Playher #1333551 11/13/2019 1:33 AM
1 Offline
I agree with the others. That is a super looking truck as-is. The fact that it fired right up and runs great is the icing on the cake.
What's in store for it???
Playher #1333582 11/13/2019 4:45 AM
Looks like you found a dandy! Congratulations!
I love my '47, but have often wished it was a '46.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Playher #1333629 11/13/2019 5:03 PM
Crusty Old Sarge
Crusty Old Sarge
I wouldn't change a thing, she's mighty straight and solid for her age. Very nice find.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Playher #1333722 11/14/2019 5:51 AM
Thanks guys. Im a big fan of leaving things original if at all possible. To date, I have replaced the master and wheel cylinders and bled brakes, topped off the coolant, changed oil 3 times(man was it black!) to flush it all out, rebuilt the light switch, rebuilt the heater, rebuilt carb, rebuilt the generator, cleaned and flashed the regulator/generator and replaced all the light bulbs.I think the last guy either had a regulator problem or jumped it with a 12 volt because every bulb was burnt and then they disconnected all the wiring which is all original and in great shape. Once I hooked it all back up, installed new bulbs and the repairs listed above, everything worked like it should including the turn indicators and cigarette lighter!
I will repair the original seat and repair or replace the wiper header and wiper motor, replace the door and window seals with the old style cloth type, rebuild the old little defrost fan that is mounted on the windshield center frame then drive the heck out of it. Haven't been this excited about a project in a long time. The raw boned rugged yet delicate style of this thing really inspires me. The grand kids and I are gonna hit downtown Buffalo WY for the Christmas parade on December 7th. Ho Ho Ho
Question, How many of the following are OEM equipment, dealer, or owner installed?
1. Fog lights
2. Cab marker lights
3. Governor
4. Heater
5. Turn indicator and lights
There is only one rear factory looking park/brake light with factory wiring at the driver side complete with license plate bracket. Is this factory correct?
There is no factory wiring, light or light bracket at the passenger side rear park/brake and no signs that it was cut off. The turn indicators have their own wiring to both the front and rear and are not incorporated into the factory harness.
Playher #1333732 11/14/2019 12:50 PM
Others will know more than me but I would say the marker lights and governor are factory, the other items could be factory or dealer options or aftermarket. Sounds like they were all installed long ago, the wiring insulation and terminals would tell that story. If that matches the known factory stuff you are in like Flint and it could not get any better. One tail light was standard. I am very jealous of your truck.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
