2 members (ShopRag, GradyB), 116 guests, and 1 robot.
Topics128,035
Posts1,055,564
Has anyone used Jim Carter's 2.5" upgraded rear leaf springs or side engine mount kit (stock front suspension)?
Plans are to go with either the 350/350 combo or 350/700-R4 combo in a 1950 Chevy 3100.
Bob
1950 Chevrolet 1300
have not used jc's i used chassis engineering in my 49 motor mounts bolt in they also have a trans crossmember that bolts to the original location. about $160.00 for both. as far as rear springs i just installed their bolt in rear end kit 2 1/2 in springs with teflon sliders upper and lower shock mounts, shocks, front and rear spring mounts got a 4-5 inch drop all their stuff comes with very good simple instructions ialso used their pacer front end kit which i think is the same one jim carter sells. recomend them highly . my two cents anyway..........
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
