| | | Forums66 Topics128,047 Posts1,055,622 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | So my new to me 1940 1.5 ton won’t start now, it’s not getting gas to the carb. It has a clear Fuel filter so I can see there is no gas in it. Has plenary of gas in the tank. What options are there for fuel pumps for a 216 and who sells them? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Have you purged the whole fuel line, including all fittings? Does it run OK if you dump some fuel in the carb? Is the fuel in the tank modern or antique? Is your fuel pump there, if so, take it with you to match up.
Ed
| | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | Sometimes it runs and has fuel to the carb, sometimes it doesn’t. Right now it doesn’t.
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | You might be able to get a fuel pump at your FLAPS. If not you can get fuel pumps and or rebuild kits on line.
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Trash/rust in the tank blocking the fuel line. Take the line off at the pump and see if anything is flowing to the pump.ðŸ›
