3 members (Bill Hanlon, 32Fordpuchoptop, 1 invisible), 103 guests, and 2 robots.
Topics128,049
Posts1,055,635
#1333020 11/08/2019 7:46 PM
So my new to me 1940 1.5 ton won’t start now, it’s not getting gas to the carb. It has a clear
Fuel filter so I can see there is no gas in it. Has plenary of gas in the tank. What options are there for fuel pumps for a 216 and who sells them?
Tony292 #1333037 11/08/2019 10:09 PM
Crusing in the Passing Lane
Have you purged the whole fuel line, including all fittings? Does it run OK if you dump some fuel in the carb? Is the fuel in the tank modern or antique? Is your fuel pump there, if so, take it with you to match up.
Ed
EdPruss #1333045 11/08/2019 11:35 PM
Sometimes it runs and has fuel to the carb, sometimes it doesn’t. Right now it doesn’t.
Tony292 #1333048 11/09/2019 12:04 AM
Ex Hall Monitor
Ex Hall Monitor
You might be able to get a fuel pump at your FLAPS. If not you can get fuel pumps and or rebuild kits on line.
Tony292 #1333050 11/09/2019 12:14 AM
Trash/rust in the tank blocking the fuel line. Take the line off at the pump and see if anything is flowing to the pump.🛠
