1 members (NofoolN), 125 guests, and 5 robots.
Topics128,186
Posts1,057,317
Members48,469
This seems to be a common problem not having the rear emergency brake hardware inside the drums when you remove them. Would any of you be able to please provide me with a actual picture of how the levers are connected inside of the drum on a 3/4 ton rear hub? It seems I may have to build the parts and I just need to see how it is all put together.
Thank you, Shawn
Check your PM.
Mike
1951 3100 5 window
