0 members (), 132 guests, and 1 robot.
Topics128,285
Posts1,058,276
Members48,483
Moderated
Moderated
Hey guys! New to the forum, just purchased a very nice looking 3100 with matching number 235/ Hydramatic.
I’m having problems with the truck shifting properly. Shifts fine 1st to 2nd, 2nd to 3rd requires high rpms then letting off the accelerator to get it to shift and 3rd to 4th same scenario!
I need some advice, please! [img]https://www.stovebolt.com/ubbthread...6B89580-955E-446F-B1F5-25FF3A6E49A9.jpeg[/img][img]https://www.stovebolt.com/ubbthread...46C48D9-C4DF-4799-AF5F-99268BB9EC61.jpeg[/img]
Welcome here Heng. This question is better asked in the driveline shop, so, I'll move it there for you.
Another quality post.
Real Trucks Rattle
Short answer- - - - -reduce the throttle pressure a little. There's a mechanical linkage from the carburetor to the transmission with a turnbuckle-type adjustment in it. To make the trans shift sooner, adjust the linkage so the small bellcrank on the side of the transmission does not travel as far when the throttle is opened. VERY small adjustments can make a big difference in shift points, so don't overdo it.
Longer answer- - - -Adjusting throttle pressure for a sooner, softer shift sometimes reveals a more serious problem- - - - -worn or maladjusted bands. You'll need a factory service manual to do a proper band adjustment. There aren't any real shortcuts to this procedure, and shade tree methods usually result in worse performance and possible internal damage.
Thanks, Jerry
Someday I hope to have my H-M back on the road - I am not looking forward to making those "touchy" adjustments, again.
Moderated
Moderated
Appreciate the reply Jerry.
I took her to a classic car mechanic to see if he could diagnose the issue and do the proper fix, I stressed to him that the H-M was different than the power glides but he was very confident that he could fix the issue. I’ll keep you guys posted on the repair.
