| | | Forums66 Topics128,018 Posts1,055,342 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | I'm having trouble deciding which route to take to get IFS on my 1957 Chevy 3100. So far I have been looking at the Heidt's Mustang II and Superide kits. Does anyone have any experience with either one? How are the other brands, such as TCI, Nolimit, Fatman? My main interests are ease of installation and ride.
Another option I've been thinking about is the 70-81 Camaro front clip, mostly because a guy out here likes to do it.
1957 Chevy Stepside 1993 GMC Sonoma
| | | | | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | I installed an MII kit from Progressive http://www.progressiveautomotive.com/street.htm The installation was so easy I did it twice - DOH! {Mark the axle centerline on the frame (drill a small hole so it doesn't get ground off during prep) before you remove the sheetmetal!} It rides fine and has stood up great to three years, 29000 miles of 4 season driving on Illinois roads. | | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | I've heard that the fatman IFS kits are hard to adjust. I installed a mustang II IFS from Southern Rods & Parts on my 52, The instructions that came with it were nowhere near complete or comprehendable. | | | | | Joined: Dec 2002 Posts: 3,437 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,437 | Heidts in my 39... sits a bit low for my liking, but otherwise works very well.. It's got big camaro brakes on it.
| | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by chuckthetruck: I installed an MII kit from Progressive http://www.progressiveautomotive.com/street.htm
It rides fine and has stood up great to three years, 29000 miles of 4 season driving on Illinois roads. Thanks for the advice. I'll check it out.
| | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by Rusty Rod: Heidts in my 39... sits a bit low for my liking, but otherwise works very well.. It's got big camaro brakes on it. Which Hedits did you get, the Mustang II, or the Superide? Did you install it yourself?
| | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by HighSchool hauler: I've heard that the fatman IFS kits are hard to adjust. I installed a mustang II IFS from Southern Rods & Parts on my 52, The instructions that came with it were nowhere near complete or comprehendable. How did it work out?
| | | | | Joined: Nov 2005 Posts: 88 Member | | Member Joined: Nov 2005 Posts: 88 | After a lot of thinkin and measuring we finally got it on there. It sits just right with a nice rake to it. We (me and my dad) did all the welding on it and the rest of the truck. If you had to pay someone to weld it on for you, it woulda cost a lot of money. A little elbow grease costs a lot these days. It's a good IFS if you don't mind the work. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I had good luck with the TCI frontend very easy to install.Just gotta make sure your measurements are correct.I had to cut one coil off of the springs.Truck sets a little low,just the way I like it.Drives and handles great.The power steering is worth the extra money.They use a TBird R&P system.If you use a GM pump you have to put a pressure reducer valve in it.GM puts out about 1300 PSI,TBird only needs 7 to 800 PSI.Without the reducer valve you will blow the seals in the unit.There are several good aftermarket frontends out there,Heidts,Fatmans etc.Biggest thing to remember is to follow the instructions to the TEE. | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by HighSchool hauler: After a lot of thinkin and measuring we finally got it on there. It sits just right with a nice rake to it. We (me and my dad) did all the welding on it and the rest of the truck. If you had to pay someone to weld it on for you, it woulda cost a lot of money. A little elbow grease costs a lot these days. It's a good IFS if you don't mind the work. The welding would be a problem for me since all I have is one of those ARC/MIG combos, and I need more practice with it. I don't mind spending some money for the welding. I may have to search to find somebody good.
| | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by dale937: I had good luck with the TCI frontend very easy to install.Just gotta make sure your measurements are correct.I had to cut one coil off of the springs.Truck sets a little low,just the way I like it.Drives and handles great.The power steering is worth the extra money.They use a TBird R&P system.If you use a GM pump you have to put a pressure reducer valve in it.GM puts out about 1300 PSI,TBird only needs 7 to 800 PSI.Without the reducer valve you will blow the seals in the unit.There are several good aftermarket frontends out there,Heidts,Fatmans etc.Biggest thing to remember is to follow the instructions to the TEE. Thanks for the advice. I've been thinking about either Heidts or TCI, but the Fatman seems to be a good deal for what you get.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | My son and I tacked welded out our TCI frontend and then had a professional welder come in to finish the job. Got him to come out on a Sunday afternoon, was very reasonable. We wanted to make sure everything was welded solid. Great for peace of mind. | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by coach-frank: My son and I tacked welded out our TCI frontend and then had a professional welder come in to finish the job. Got him to come out on a Sunday afternoon, was very reasonable. We wanted to make sure everything was welded solid. Great for peace of mind. That's what I was thinking about doing since I can handle all of the assembly work no problem. Thanks for confirming that it's a good idea. By the way, which TCI front end did you get?
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | We got the mustang 11 not the custom. We took the body off the frame. Tacked everything in. Put the frame on jack stands for the welder. We even flipped the frame over so he did not have to weld from underneath. He did the whole thing for $200. Said he normally charges $150 just to bring out the truck with the welding machine, but since we had everything ready for him plus flipped it for him, he cut us a brake. He did the whole thing in less than an hour.Even welded our 4link rear for us. | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by coach-frank: We got the mustang 11 not the custom. We took the body off the frame. Tacked everything in. Put the frame on jack stands for the welder. We even flipped the frame over so he did not have to weld from underneath. He did the whole thing for $200. Said he normally charges $150 just to bring out the truck with the welding machine, but since we had everything ready for him plus flipped it for him, he cut us a brake. He did the whole thing in less than an hour.Even welded our 4link rear for us. That sounds like a good deal to me!
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | I will add that I also had a friend bring his MIG welder over to do the final welding.I had it installed and tacked in with my 220 AC stick welder.He had it in nice and solid in less than an hour.I could have welded it in myself with the stick welder,but I dont weld that much anymore.Everything else on the truck I welded. | | | | | Joined: Nov 2005 Posts: 24 Junior Member | | Junior Member Joined: Nov 2005 Posts: 24 | I have a 57 GMC swb/step 114wb... I am planning on swapping a ifs from 71-87 truck onto my factory frame without cutting or welding other than boxing the frame for added stegth... it took me a while to find the infomation needed on track width but I finally found it.. the suspension of the 60-87 is bolted in... it can be unbolted and matching holes drilled into the 57 frame for a bolt in operation.... trouble is the track width... here's the info I have TRACK WIDTHS hub to hub
1. 55-59 Chevy Pickup 62in 2. 47-55 1st Series 60-62in 3. 71 Chevy Pickukp 63 3/4in 4. 78-up Monte Carlo 58in 5. 76-80 Camaro 61 1/2in 6. 68-72 Chevelle 61 1/2in 7. 89 Trans Am 62
I found these on the web... so as always- do your own measuring before doing anything as drastic as cutting a frame...THESE ARE FRONT TRACKS- rear may be different..sometimes a little narrower to accomidate wider tires.. The practice of unbolting and redrilling and attaching ..is one that I am familiar with.. it is how 18wheeler frames are shortened... for vehicles carrying 80,000 pounds.. I am planning on running narrowed control arms on the suspension.. hopefully I will gain an inch on each side(2 inches total)and be right there at 61 3/4 inches on front track... 1/4 inch less than normal 62 on the 1957 model. This will allow me to run low dollar yet bulletproof factory suspension... theoretically this can be done on suspensions back to the 1960 model... I mentioned 71-up because of factory disc brakes... BE WARNED.. I have a friend who used a 71/disc front on his 59.... it currently looks TERRIBLE.. .. very ungainly... wheels are sticking out quite ackwardly from under the fenders...yuk.. there are some who have addressed this problem with wheel offset alone...to some success... but I like the deep look on the wheels...to accentuate their width... and I want absolutely no part of the look my buddy with his 59 got.. Fatman makes narrowed control arms... they are very pricey...but still cheap when compared to a complete $1300-$1800 dollar Mustang 2 fully complete set up.. I've found a fabricator in the Carolinas who makes custom control arms but I have no price yet.. I am probably going to pick through my racing contacts and find an engineer/fabricator who can complete the task and not offend the laws of physics...or hopefully my pocket book.. I can get a junkyard front suspension with brakes for under $100.... another good reason to go this way is there are aftermarket lowering kits available at many heights in use with this IFS...so tailor the height to your liking.. Eibach..and many other quality racing spring MFG companies make springs for this front... or keep it factory for a softer ride..up to your taste and desires.. Good luck on whichever way you choose... many of the Mustang II kits are quality pieces.. -K | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | If you are not dead set on a M11 set up you should check out the Dakota crossmember from Industrial Chassis in Phoenix. I have one in my 57 and love it. The xmember is a little pricey but you buy everything needed for a song at the local pick & pull to finish it off. What you end up with is a truck front end with big brakes that is the correct width for a TF. The rack is a high pressure piece that needs no special pump or valves to make it steer right. Check it out. | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by KyleDallas: I have a 57 GMC swb/step 114wb... I am planning on swapping a ifs from 71-87 truck onto my factory frame without cutting or welding other than boxing the frame for added stegth... it took me a while to find the infomation needed on track width but I finally found it.. the suspension of the 60-87 is bolted in... it can be unbolted and matching holes drilled into the 57 frame for a bolt in operation.... trouble is the track width... here's the info I have TRACK WIDTHS hub to hub
I found these on the web... so as always- do your own measuring before doing anything as drastic as cutting a frame...THESE ARE FRONT TRACKS- rear may be different..sometimes a little narrower to accomidate wider tires.. The practice of unbolting and redrilling and attaching ..is one that I am familiar with.. it is how 18wheeler frames are shortened... for vehicles carrying 80,000 pounds.. I am planning on running narrowed control arms on the suspension.. hopefully I will gain an inch on each side(2 inches total)and be right there at 61 3/4 inches on front track... 1/4 inch less than normal 62 on the 1957 model. This will allow me to run low dollar yet bulletproof factory suspension... theoretically this can be done on suspensions back to the 1960 model... I mentioned 71-up because of factory disc brakes... BE WARNED.. I have a friend who used a 71/disc front on his 59.... it currently looks TERRIBLE.. .. very ungainly... wheels are sticking out quite ackwardly from under the fenders...yuk.. there are some who have addressed this problem with wheel offset alone...to some success... but I like the deep look on the wheels...to accentuate their width... and I want absolutely no part of the look my buddy with his 59 got.. Fatman makes narrowed control arms... they are very pricey...but still cheap when compared to a complete $1300-$1800 dollar Mustang 2 fully complete set up.. I've found a fabricator in the Carolinas who makes custom control arms but I have no price yet.. I am probably going to pick through my racing contacts and find an engineer/fabricator who can complete the task and not offend the laws of physics...or hopefully my pocket book.. I can get a junkyard front suspension with brakes for under $100.... another good reason to go this way is there are aftermarket lowering kits available at many heights in use with this IFS...so tailor the height to your liking.. Eibach..and many other quality racing spring MFG companies make springs for this front... or keep it factory for a softer ride..up to your taste and desires.. Good luck on whichever way you choose... many of the Mustang II kits are quality pieces.. -K Thanks for all of the great information.
| | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by Richie Z: If you are not dead set on a M11 set up you should check out the Dakota crossmember from Industrial Chassis in Phoenix. I have one in my 57 and love it. The xmember is a little pricey but you buy everything needed for a song at the local pick & pull to finish it off. What you end up with is a truck front end with big brakes that is the correct width for a TF. The rack is a high pressure piece that needs no special pump or valves to make it steer right. Check it out. I was taking a look at that. I'll probably give them a call to find out more information. How hard was it t0 install?
| | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | I don't think that it is any harder to put a Dakota crossmember than it is any other crossmember.Basic welding and measuring skills still apply. What you end up with is IMHO a much better front end for a truck. Everyone has jumped on the M11 bandwagon like lemmings in heat. If you want to learn more about M11's read the horror stories at hotrodder.com about lower control arm bolt failures. The Dakota comes from a very similar vehicle in length, weight.and most importantly center of gravity. The roll center of a M11 is so far off from that of a truck it's not even funny. You got a little Model A, go for the M11 you got a truck that you might use as a truck go Dakota, You won't look back. Talk to Steve at I C 602 278 6800 | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by Richie Z: I don't think that it is any harder to put a Dakota crossmember than it is any other crossmember.Basic welding and measuring skills still apply. What you end up with is IMHO a much better front end for a truck. Everyone has jumped on the M11 bandwagon like lemmings in heat. If you want to learn more about M11's read the horror stories at hotrodder.com about lower control arm bolt failures. The Dakota comes from a very similar vehicle in length, weight.and most importantly center of gravity. The roll center of a M11 is so far off from that of a truck it's not even funny. You got a little Model A, go for the M11 you got a truck that you might use as a truck go Dakota, You won't look back. Talk to Steve at I C 602 278 6800 Thanks. I'll give them a call.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | I've considered an IFS for my 57 GMC,but everything I've seen so far lowers the front;I'd like my truck to sit at stock height. Anybody know of a swap that will sit stock and not require a ton of mods to make the sheet metal/bumper hang right? Speed | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | The Dakota lowers the truck less than 2 inches. | | | | | Joined: Sep 2004 Posts: 120 Member | | Member Joined: Sep 2004 Posts: 120 | it you want to stay a stock hieght keep a strait axle. It you want ifs the best i have used is Chassis Enginering it is bolt on and uses mustange 2 stuff on is. You can do it in a weekend. | | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | gmckustom, you referring to the Pinto kit?
Looks like $625 for the crossmember; $2000 when all the goodies are added, plus tax and shipping?
A CPP stock axle upgrade to disc brakes is ~$350; and maybe $500 for a set of Eaton Springs... Throw in another $200 for a sway bar putting it just over a grand, or about half the cost of IFS?
Sound about right, or am I missing something? mark. '51 KY 3100 | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by gmckustom: it you want to stay a stock hieght keep a strait axle. It you want ifs the best i have used is Chassis Enginering it is bolt on and uses mustange 2 stuff on is. You can do it in a weekend. Bolt-in sounds good!
| | | | | Joined: Jul 2005 Posts: 2 Junior Member | | Junior Member Joined: Jul 2005 Posts: 2 | Im looking for more info on the Dakota xmember? Does anybody have a web site or phone number? | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by burbcrazy1: Im looking for more info on the Dakota xmember? Does anybody have a web site or phone number? http://www.industrialchassisinc.com
| | | | | Joined: Jul 2005 Posts: 2 Junior Member | | Junior Member Joined: Jul 2005 Posts: 2 | | | | | | Joined: May 2005 Posts: 47 Member | | Member Joined: May 2005 Posts: 47 | Originally posted by burbcrazy1: Thanks for the help. No problem.
| | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | Hey 13BAce, Have you talked to I C, If so what is the current cost of the xmember. It's been 4 years since I bought mine. Just being nosey or nosy depending where you live, Thanx Richie Z | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | Never mind, I just came from their site. Not too bad a price. I think I paid 675 four years ago. His complete front end is not cheap. I bought a complete Dakota truck from a junk yard for a 100 bucks. Rotors, pads, ball joints, and tie rod ends and it was over, way under a grand. | | |
