1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#1332537 11/04/2019 6:55 AM
Are the engine mounts on an LT1,(1995) the same as a 350? I'm getting ready to install a Mustang II in my 1950 3100. I see that the manufacturer can sell you engine mounts for a 350, however, I haven't seen anything for an LT1 350. Maybe they're are out there I just haven't seen them.
I'm pretty sure the motor mounts are the same. The heads have some differences from the 350. You should be able to mock up with a 350/5.7 block.
SimS
