| | | Forums66 Topics128,038 Posts1,055,471 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | So my 1940 1.5 ton with a 216 isn’t exactly road worthy. All six tires are about 30-40 years old and cracked badly. It also doesn’t have a tachometer and the speedometer doesn’t work. I do have access to some gravel backroads and I downloaded a speedometer app today and took it for a spin. It seems to max out rpm very quickly in 1-3, but in 4th I can get it up to 50 MPH on the iPhone app and it isn’t really redlining at that point. I couldn’t go faster because I didn’t feel safe bug is seems to do 50 with ease and if I had more straight road I think it could’ve easily gone faster.
Wish I had a working tach and speedometer so I could calculate the gear ratio! Maybe I’ll just have to break down and remove the rear diff cover and start counting teeth! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Cleaner to just jack up one wheel and count revs. Whatever it is, it will be slow. What do you want to do with the truck?
Ed
| | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | Just some trips to Home Depot, tractor supply here and there. Not a lot of miles but a lot of smiles. And having a 1.5 ton would be a blessing on the farm, I could actually load Up a ton of bricks or concrete bags, or whatever and not be overloaded.
The main issue is that between my farm (horseshoe bend Idaho) and home Depot (eagle Idaho) is a 7% grade mountain. It’s literally 5 miles up 4 miles down.... and I see lots of trucks overheated on the side of the road every day in the summer, mostly F250 and F350 with way too large a travel trailer.
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Leave it the way it is...it sounds perfect to me! You may be slow going up the mountain, but you'll be glad to have those lower gears when going down. The factory had the gears and brakes dialed in...messing with one will have an impact on the other. Mike B  | | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | Only issues with counting this way is that I can’t see the driveshaft, due to torque tube. | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | I had a 46 2-ton that I used for my business. Top speed on the interstate I was able to accomplish was about 65. It didn't like it and was a little uncomfortable. 60 was alright. 58 was good. 55 was great. I would routinely put 10,000 pounds on the back and run across town for deliveries. Largest load was 12,500. Mostly stock. refreshed 235 engine. Updated electrical system. Disc brakes on the front with a dual circuit master. Stock exhaust manifold with 2 1/4" exhaust pipe.
Keep it how it is. Get some good tires and tubes on it. 7.5 in the front. Maybe 8.25 in the rear, but 7.5 might be a better option with the 216 to give you a little bit more torque for those heavier loads.
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you really want to know, put in in high gear, take the plugs out, have a friend turn while you count, or to eliminate any work, roll it down a gentle hill, mark one fan blade, count wheel and fan revs.
Ed
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | For torque tube type driveshafts we use an old hand held tach/dwell meter and a variable strobe light. Run the engine rpm up to 2000rpm and measure the rpm of the jacked up rear wheel. Engine rpm divided by wheel rpm equals rear end ratio. With an open rear end you multiply by two or on a limited slip you jack up both wheels and read direct. Example: engine rpm 2000, wheel rpm 300, rear end ratio is 6.66.
Evan
| | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | Well I cleaned enough crud off the axle with a wire brush to find the numbers 37 and 6, rings and pinion tooth counts which comes out to 6.16
Anyone successfully added a 5 speed to a big bolt? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Unless the 5-speed is an OD transmission, the final gear is still the same as your 4-speed...1:1 or direct drive. Mike B  | | | | | Joined: Oct 2019 Posts: 238 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 238 | Most 5 speeds are overdrives. | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Most 5 speeds are overdrives. In these old rigs I'd not make that assumption, most I've seen in farm trucks of this era are direct drive in 5th.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I added a 'brownie' to my 1.5 ton GMC firetruck with 302 engine. 6.6 diff. ratio, made a very useful high gear. 5 speed direct trans.
Many 5 speed OD trans' are just converted direct trans' which they take 3rd. gear to make OD. That leaves a big gap without a 2 speed rear, so with a load, get stuck in too low gear because of big gap.
Ed
| | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Most 5 speeds are overdrives. Most car 5 speeds are overdrives. Most 5 speed Clark, Fuller, Spicer, Eaton, etc. truck transmissions were not overdrive.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | NP- 540 series, some Clarks, IHC(Warner gear) were some trans' that came in direct and OD versions that have a wide ratio gap to accommodate OD.
Ed
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | I put a Ranger overdrive in my 58. Goes between the bellhousing and SM420. I like the drop in RPM, I should have put bearings in it and the trans before I just dropped them in though! I may do that later this winter. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | What size tires are you running? I'm running 7.50 20s on my 46 COE and 45 MPH is tops 8.25s or 9.0 20s you would gain 5 or maybe 8 MPH. I'm happy with the 7.50s because I know I will be able to stop easier with all the original running gear! | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | What size tires are you running? I'm running 7.50 20s on my 46 COE and 45 MPH is tops 8.25s or 9.0 20s you would gain 5 or maybe 8 MPH. I'm happy with the 7.50s because I know I will be able to stop easier with all the original running gear! I am running 9r-22.5 all the way around. | | | | | Joined: Feb 2010 Posts: 476 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 476 | That would make a lot more speed. How much over 7.50 x 20s ? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | The 9.00-22.5 is only one size bigger than your 7.50-20...it will have the same diameter as a 8.25-20. The 8.25-20 and the 9.00-22.5 are about 2" taller at about 39". Mike B  | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 |
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
