2 members (Otto Skorzeny, Jon G), 86 guests, and 3 robots.
Topics128,089
Posts1,056,344
Members48,442
AD Addict & Tinkerer
I just bought three point seat belts and have studied several post on installing them in a 5 window AD truck. I understand how to install all of the anchor points but can’t seem to figure how the belts that have the buckle are routed. I’ve posted a picture of my seat frame with an arrow pointing to the problem area.
If it was routed in front of the frame, it would end up turning back over the sharp edge to get around the back of the bottom seat cushion. In an accident, it would put allot of pressure on the seat bottom surely bending the two front clips holding the seat in place, causing the seat to dislodge sliding forward. The front edge of the frame is sharp and could cut the belt. Not a good situation.
Routing it behind the frame seems to be a better option but that too seems to have some routing issues too. The sharp edge on the back of the frame could also cut the belt.
The other thought I had was how does moving the seat affect the routing?
I have never installed these belts before and are looking to those that have.
Phil
Project Journals
Stovebolt Gallery Forum
Insomniac
Insomniac
I cut rectangular holes big enough for the buckle to go through in the area where your arrow points. I got this idea from someone else on this forum who posted pictures of his installation but I believe he installed just the lap belt. That's OK as in this area, the lap belts and the three point belts are similar. Should be able to find the pictures using the search function.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I'd suggest getting some steel tubing, split it along one side and fit it over the sheet metal to make a smoother opening. That would reduce the possibility that the raw sheet metal edges would cut the belt.
Fox Offline
I used Deve’s tech tip. It worked well for me on my AD. I only have a 3 window though.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Former BMW Rider
Former BMW Rider
I used Grigg's approach as detailed below. It worked great and the grandkids love to ride in Grandpy's '47!
Originally Posted by Grigg
Now seat belts. This project turned out to be really quick and easy; much to my surprise after thinking about it and reading other tales and how to's on seat belt installs.
First I removed the seats and seat frame which revealed a very broken mount on the drivers side and some broken spot welds on the seat frame.
PICTURE 2 cracket seat mount
Unfortunately I forgot to take a picture after, but imagine that as a spider web of welds and a bit of new metal.
Center seat brace was much easier, drill out failed spot welds and plug weld to repair.
PICTURE 3 seat brace before
PICTURE 4 seat brace after
These are the belts I ordered pictured complete with invoice and part numbers. They all worked out fine however I'd get the fixed end longer next time though 20" does work OK (you'll see why later).
PICTURE 5 seat belts and invoice
Where to mount them in the center?
I sat in the seat and measured/estimated that my hip was 5" from center as I'd normally sit/drive. So I installed the center anchors 10" apart and centered in the cab. They're as close to the riser as the hardware allows, 5/8".
PICTURE 6 center seat belt anchor holes
This is the only tricky part where a little head scratching comes in. If you now pass those seat belt straps up through the seat they have to take a pretty circuitous rout to get out between the cushions. Ideally the seat belt straps are straight from anchor to your lap however this is not possible in an AD truck without modification.
Here's the modification, two slots in the seat frame back for them to exit from.
PICTURE 7 belt slot layout
PICTURE 8 belt slot cutting
PICTURE 9 belt slot deburing/rounding
As you can see again 10" on center. Slots are 2.5" wide, 1/2" tall and centered about 5/8" down on the seat frame. Real easy to cut by first drilling the end holes and connect with jigsaw.
Did a good job softening the edges with file, deburing tool, and flossing with sand paper. I'll look into using a length of very small rubber hose split and fit over the sheetmetal to make a sort of grommet to further soften the edge.
PICTURE 10 center belts installed.
The outside anchors for the retractors turned out to be exceptionally easy. I would use these same locations (or nearly so) and method for plain non retractable lap belts and also for shoulder belts. Figured this out by just holding the retractor about where it made good sense, allowed straight line to hips, and where it fit and where anchor plate/nut under the cab would fit.
These ended up being 3-5/8" back from the seat riser and at that point about 2-1/8" in from the radius edge of the cab floor. Drilled a small pilot hole from the top and then under the cab to drill/enlarge to full size, 7/16".
PICTURE 11 outside belt hole locations
PICTURE 12 approx. angle/assembly of retractor and angle bracket.
PICTURE 13 Installed, same on other side.
This whole seat belt project including the weld repairs to my seat frame and mount only took a couple hours from removal to reinstalling the seats including head scratching and figuring out the plan. One of the only times I've ever completed a project in less time than I estimated.
Installing seat belts can be done without welding and without removing the gas tank!
The 20" center belts are shown at full extension, if you'd like the buckle to be at your front instead of your side then they'd need to be longer. The retractable part is plenty long to reach either way.
PICTURE 14 seat belts done
PICTURE 15 seat belt from the side
Next, prepping for the 4-5 hour drive to the Stovebolt Homecoming in a couple weeks. Homecoming Info
Grigg
Andy
His: 1947 Chevrolet 3104
Hers: 2008 American Saddlebred
"I proudly Stand for the Flag and Kneel for the Cross" Unknown
Thank, Andy & Grigg
Does this work with 3-window and v5 window cabs?
Former BMW Rider
Former BMW Rider
I believe so, since it really addresses lap style belts. Grigg does mention in the text that the hole placement would also work for the shoulder belt (three-point style). I opted for lap belts because I didn't like the location of the should belt/anchor in my five window cab. It would have been too high for me.
Andy
I completed the installation of my 3 point seat belts. I had not seen Griggs post prior to me cutting the slots to route the belts thru the seat frame. I cut mine in the same location but longer to accommodate an additional lap belt for a middle passenger. When I cut the rectangular holes, I slotted them and folded them over so I didn’t leave the sharp edge.
I also followed Deve’s location for the retractors but with my gas tank still installed I opted to bolt the L bracket both thru the floor and the seat riser instead of welding it in. I located the brackets on the pillar a bit higher so it wouldn’t interfere with the windless weatherstripping. I also added one pop rivet under the bolt hole to keep it in place. This rivet is hidden by the d-ring and belt. The position seems good to me, not too low or high.
Since I was adding a third belt, I opted to fabricate my own L brackets from 3x3x1/4” angle, to accommodate two belts. These were attached with oversized 1/4” steel plates thru the cab floor which I drilled and tapped for 7/16-20.
I also increased the size of the bolts that attach the seat frame to the adjusters to 3/8” grade 8 and added some weld to the adjuster brackets where spot welds were holding the assembly together.
Phil
Project Journals
Additional pictures:The forth picture is the support plate that is under the cab for the retractors. These are 1-1/2” flat bar, 1/4” x 4” and is just above the cab mount. These were also tapped for 7/16-20.
Phil
Project Journals
Moderated by  ndkid275, Phak1
