6 members (55shaker, Otto Skorzeny, Gray_Ghost, Hush, 52Carl, JW51), 155 guests, and 2 robots.
Topics128,108
Posts1,056,238
Members48,437
#1332231 11/02/2019 12:36 AM
Anyone know of a source for this clip that holds one side of the defroster ducts to the dash?
Thx,
Derek
Derek,
Go to your local Ace or any full service hardware store and look for a S-style cage nut also called Clip-On Enclosed Hex Nuts. I have attached a photo so you can see what it looks like. You may find one you could modify (remove the nut) and use on your vents.
Harold
Harold
Thx Harold! The clip I’m looking for is shown in my photo. It is an S-style clip but it clips over the end of the duct and then onto the dash...no fastener needed on this side if the duct.
Go by and visit with the manager of your local Paint and Body Shop. Bet they have a supply on hand or can point you in the right direction.🛠
Derek,
I know the clip you are looking for. That is why I suggested picking out the S-style cage nut close to the size you need & remove the nut and adjust the openings to fit your vents.
You can contact Advance Components, (972)446-5500. They have the clip in the photo. They may have the size you need.
Harold
Harold
Thx Harold. I did go to Advance Components and found this one! Doesn’t look like the same size but may be good enough!
Riding in the Passing Lane
That looks like the clip that goes on the bottom of the fan shroud on some 60's 70's trucks. They are available at the specialty suppliers.
George
1972 Chevy c10 Cheyenne Super
Yeh it’s real similar. The fan shroud clip is square and flat. This clip is more round on top and longer on top than bottom.
Moderated by  ndkid275, Phak1
