1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#1332058 10/31/2019 3:18 PM
Discovered leaking rear wheel brake cylinders both sides. Time to install new. The shoes have plenty of lining left so would it be prudent to thoroughly clean with brake cleaner, scuff them up and keep going or purchase new or relined ones? headscratch
Moderator, Electrical Bay
I'd buy new ones. I've seen people soak them in alcohol, gasoline, etc and they will clean up...sort of. Not like new dry ones, though.
~ Jon
So true...and allot less mess. Cheap insurance as someone once said. New it is!
AD Addict & Tinkerer
The shoes will absorb the brake fluid. You can clean the outside and scuff them up so they look good but as soon as they heat up the fluid will sweat out to the surface and cause problems.
For safety’s sake, replacing them is really your only option.
Phil
Project Journals
Stovebolt Gallery Forum
I have done this several times with oil soaked brake shoes, soak them with brake kleen and bury them in oil dry and leave them overnight
the next morning they were clean and dry and never had a problem. Over in Nam parts were a little scarce at times
You Learn more Listening than Talking
