5 members (Otto Skorzeny, 68ironhead, 32Fordpuchoptop, Guitplayer, greenie-reddy), 56 guests, and 1 robot.
Topics128,090
Posts1,056,016
Members48,430
#1332016 10/31/2019 2:42 AM
Moderated
Moderated
I have a GMC 550 with the following VIN on the data plate: W553XI024
It’s a tandem axle, 5 window truck. Has the Olds V8.
What else can be told from this number?
Does “024” mean it was the 24th 553 truck built? In just 57 or 54-57?
What does the “XI” mean? The “W”?
I know 553 indicates wheelbase.
Any help is appreciated.
If this is a 550 series GMC, I strongly suggest that post this question on oldGMCtrucks.com.
There are members who know alot about big GMCs.
Spanky reads posts here & there - he knows big GMCs.
3B Offline
Hy mikedean58, welcome, your serial number breaks down as, W = six wheeler, 553 = 158" wheelbase, X = 1956 production I believe the balance of the number is regular production number which probably started at 1001. Your truck left the factory with a 324 cu. in. Oldsmobile V8 the standard equipment was an 11" dual disc clutch, an FO90 front axle, rear axles Eaton SS(A) 34M, transmission 5 speed 541GDS3. possible auxiliary transmissions 6231A or 6231B and air brakes, hope that helps
Camp Commandant
Camp Commandant
Mike, post a picture when can. Some of us love big GMCs here too!
~ Billy
1959 GMC 860 | Pictures
Crusing in the Passing Lane
GMC posts the engine displacement as the first 3 numbers of the engine SN, 370xxxx.
That engine is a 370 or became a 370 in subsequent years.
Ed
