| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 2 Moderated | | Moderated Joined: Aug 2012 Posts: 2 | I have a GMC 550 with the following VIN on the data plate: W553XI024
It’s a tandem axle, 5 window truck. Has the Olds V8.
What else can be told from this number?
Does “024” mean it was the 24th 553 truck built? In just 57 or 54-57?
What does the “XI” mean? The “W”?
I know 553 indicates wheelbase.
Any help is appreciated. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | If this is a 550 series GMC, I strongly suggest that post this question on oldGMCtrucks.com. There are members who know alot about big GMCs. Spanky reads posts here & there - he knows big GMCs. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mikedean58, welcome, your serial number breaks down as, W = six wheeler, 553 = 158" wheelbase, X = 1956 production I believe the balance of the number is regular production number which probably started at 1001. Your truck left the factory with a 324 cu. in. Oldsmobile V8 the standard equipment was an 11" dual disc clutch, an FO90 front axle, rear axles Eaton SS(A) 34M, transmission 5 speed 541GDS3. possible auxiliary transmissions 6231A or 6231B and air brakes, hope that helps | | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | Mike, post a picture when can. Some of us love big GMCs here too!
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | GMC posts the engine displacement as the first 3 numbers of the engine SN, 370xxxx.
That engine is a 370 or became a 370 in subsequent years.
Ed
