6 members (Peggy M, J Lucas, 78buckshot, Uncles51, Youngin' Tut 59, 1 invisible), 84 guests, and 4 robots.
Topics128,174
Posts1,057,048
Members48,458
#1331171 10/25/2019 3:35 PM
Jim C. Blue
Jim C. Blue
Got my 1953 GMC "9783-HD" home yesterday afternoon. Sure hope it turns out to be better than the last one!
[img]https://www.stovebolt.com/ubbthread.../Number/12267/filename/1953GMC9700-2.jpg[/img]
It definitely has a lot of good still in it, even the old wood box is still usable. Plenty of original about it, including the 6 volt system(too bad it doesn't have the radio anymore - it was actually optioned with it!) Even has the original engine, but it is stuck. Got it soaking in penetrating oil and hope I can save it. Appears to be the 302 six!
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
Sweet!
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
That looks like a really nice truck. Congratulations. It should give you a lot of enjoyment.
1951 1 Ton Completed
Nice truck.
Keep us posted on it.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
Very nice truck. Does it have a "GMC Parts Identification " tag, on the back of the glove box lid ? The U.S. built heavy duty GMC's do.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Crusing in the Passing Lane
Nice truck, good wheels, are the wheels Budds or motor rim and wheel? Is the block stamped 302 on the machined pad behind the distributor?
Ed
Jim C. Blue
Jim C. Blue
Thanks!
Spanky: I didn't remember seeing that, but there is a tag near the passenger side hood hinge. I attached a photo. Will eventually take another look.
EdPruss: Didn't see it last I looked, but will try again now I know where. Maybe it was covered in grease. I do know the door plate says G43152.
"are the wheels Budds or motor rim and wheel?"
Wut
Great looking truck!! Hope you can get the engine loosened up. ATF is supposed to work good for that.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Big Bolt Forum Moderator
great looking project!!
Mike
The glove box lid tag, will have all the trucks spec.s, as in, engine size, axle types, trans. type, and rear axle type listed on it, type brakes, and type wheels used on it listed.
Spanky Hardy
1950 GMC 250 1-Ton
Bud wheels have tapered nuts and seats in the wheel. Motor rim and wheel have nuts with captive washers, nothing tapered.
Ed
Jim C. Blue
Jim C. Blue
Tried looking at at the engine again, but didn't see anything. Could it be hiding behind grease and dirt? Attached a photo.
The glove box tag, would it have been a sticker/decal type of tag? If so, it has since pealed off.
On machined pad behind distributor.
Ed
The glove box tag would have been attached by two small phillips screws.
Spanky Hardy
1950 GMC 250 1-Ton
Jim C. Blue
Jim C. Blue
ExPress: Nut and washer.
Attached a photo of what I found by the distributor.
Spanky: Two holes by the corner(as seen in photo) but no tag.
All I got is the tags on the door frame. Attached a photo of it.
I found explanations of the truck serial, but what about the engine code?
Looks to be a 248 engine.
Spanky Hardy
1950 GMC 250 1-Ton
3B Offline
Hy Alex Arrow, In my experience Canadian GMC engines which have serial numbers that begin with the letter "G" as on the serial number plate picture you posted are 248 engines. I believe the fact that your engine only has the numbers 248 indicates that the engine was replaced at some point in the trucks life, hope that helps.
Moderated
Moderated
Nice looking truck!
My grandfather had a truck like that - it was sold in the early Eighties. I'd like to find another one for use on our small farm.
Bryan
2 Offline
you probably have a Chevy engine, Canadian GMCs in those years come with Chevy engines when new and the truck frame would need to be modified to accept a GMC engine if someone had managed to fine one to put in there
give us a better view of the overall engine or the block casting number, but from what i see in the photos you have a replacement 235 with non factory stamped numbers (number physical size is too small)
-stan
The stamped 248 most likely denotes a replacement GMC block as mentioned above, that never had the additional numbers stamped from the original engine, Chevy never had a 248 engine.
Ed
2 Offline
GMCs didn't get GMC engines in Canada in those years
that truck originally had a Chevy full pressure 235 in it, one year before USA Chevys got the full pressure 235 in regular production
my understanding is that the GMC engines that the USA trucks have are slightly different length and so in the USA you can't swap a Chevy engine into your GMC because the front frame parts are slightly different to accommodate the respective engines
whereas in Canada, the only different between a Chevy Truck and GMC for AD years is the front grill and radiator, the tiny name plate on the dash, and a GMC horn button (there maybe a few other trivial details i'm forgetting at the moment, but they are not significant in anyway to the operation of the vehicle).
you can (and i have) swapped the Chevy engine from a GMC into a Chevy, because it's the same engine in Canada
i have never seen the GMC engine up here in person, doesn't mean it doesn't exist, but it's rare if it does
-stan
GMC's actually did get GMC engines in the Heavy Duty 9700-9700 HD series trucks. Yours is a 9700 HD. The GMC 248 was Standard, and the 270 optional.
Spanky Hardy
1950 GMC 250 1-Ton
2 Offline
yup i stand corrected, never seen a GMC engine in person up here, largest trucks i own or ever been around is my 2.5Ton
learned something new
thanks
-s
Jim C. Blue
Jim C. Blue
Thanks for the insite, everyone!
Tanner: too bad you are over in Carolina, as I have another truck.
GMC small block 6 cyl. engines are about 3" longer than Chevies, thus, one can easily put a Chevy engine in a GMC, but some mods are required to put a GMC engine in a Chevy truck.
Ed
Jim C. Blue
Jim C. Blue
Well, the engine has been soaking for a week and still won't budge. Hope I can still save it. Want to keep the GMC branded engine in it and I don't have the ability to do an engine swap.
Wanted to heat up the block, but having trouble with the block heater in it. It won't come out so I can clean and test it.
What have you been using to get it unstuck?
Ed
Be careful you don't bend a rod or damage something else. If it did not come easy, I would be taking it apart and freeing the parts one at a time to reduce the chance of damage.
Mac :{)
Jim C. Blue
Jim C. Blue
I started with Marvel Mystery Oil then over to Penetrating Fluid.
What mechanical leverage are you using to try and turn the motor over...the starter or a pry bar on the ring gear or what?
Have you removed the valve cover and confirmed all of the valves are free? One stuck valve is all it takes to lock the motor up...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Jim C. Blue
Jim C. Blue
Started with the flywheel, then the front of the crank.
That is a good idea, should be easy to check.
If you find a stuck valve, remove the entire rocker arm assembly and see if that helps.
Putting it in gear and gently rocking the truck back and forth might break it free as well, just be sure to use a couple chocks set loose so if it breaks free is doesn't roll away.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Coke or molasses poured in a clean(no oil product) cylinder will break the rings free, don't get in a hurry. The acid dissolves rust, ATF combinations are just a lube, do not do anything to rust.
Ed
Nice looking truck! Very similar to mine (52 GMC 9700) even the deck could be the same (mine is Obeco) Mine was also a Saskatchewan Truck (was in Brock) I have a running 248 GMC, and have got a Cummins 12v that I will likely be putting into it... I'm out in BC now though.
1953 Chevrolet 1100
Grandpa's truck
Story in Big Bolts
1952 GMC 9700
Story in Big Bolts
1948 Chevy Pickup
"Two brothers; two trucks"
In the DITY Gallery
I think prying on a starter ring tooth is a lot safer to try to turn the engine, front bolt on crank could strip threads, not so with starter tooth.
Ed
ATF is supposed to work good for freeing up stuck engines. A guy on one of the tractor forums I belong to swears by it.
Rich
1947 Loadmaster
Nice truck. My old neighbor uses ATF mixed with kerosene. Not sure if there was anything else in his cocktail, but might be worth a try.
AD Addict & Tinkerer
ATF is a great cleaner. Mix it with equal parts of acetone for a homemade penetrating oil. I have also added a quart to a slugged up engine, ran it for 1,000 miles before an oil change with amazing results. I did this with a ‘65 Chevy van with either a 230 or 250 (can’t remember) and a ‘77 V-8 non stovebolt that sounds like creep. In both cases it cleaned them enough to stop the lifter noises.
Phil
Project Journals
Stovebolt Gallery Forum
