3 members (chevyb, Otto Skorzeny, Perro), 222 guests, and 1 robot.
Topics128,076
Posts1,056,008
Members48,433
#1331521 10/28/2019 4:26 AM
Not sure if this is part of the design but water was ejecting from a small port to the right (driver's side) and slightly lower than the hole pictured. (which I think is the flywheel cover?)
The radiator level has remained the same the last couple times this happened - which curiously have been after a rain?
I searched for overflow discharge ports but did not get results to explain. Looking in the online shop manual I'm not coming up with anything either.
Its a 1951 chevy 3600
Rog
There is a drain for the cowl vent at the rear of the engine. If the level in the radiator has not gone down I would think that is where the water is coming from.
Tommy
59 apache 1/2t
261 short stepside
Is it water or antifreeze?
Rick
1939 Chevrolet Stake Truck
I should have specified... It looks like slightly dirty water.
I'm curious why the cowl would drain that way? I'm still looking for a shop manual drawing.
There was a short black rubber hose that was/is connected to the metal drain tube.
That drain hose usually directed water onto the valve cover (or/and down rear passenger side of the block).
A silly design because, if directed incorrectly, the water could go onto the top of the valve cover and then enter openings in the (1954 and earlier) valve cover. Water would then drip/drain over the inside of the head.
Do you have that drain hose?
I used a plastic tubing connector to add a longer length of hose down the passenger side of the block. THe hose is long enough to empty beneath the oil pan.
AD Addict & Tinkerer
Place a pan under the vehicle in the area that you saw the puddle so next time it rains, you’ll be able to capture some of the fluid. You’ll should be able to distinguish if it’s anti freeze or water.
Phil
Project Journals
Stovebolt Gallery Forum
What Shop Manual and what page/illustration (that will then place us all "on the same page"?
Yes there is a black hose draining the cowl and its short; looking to drip directly down the firewall. The manual I'm referring to is online at: http://chevy.oldcarmanualproject.com/shop/1948_51truck/index.htm
Thanks for all the suggestions.
Give me a hint - what page in the 1951 Shop Manual?
This page? It clearly supports my post, above?
Add an extension tube onto that drain tube.
Oh sorry. I meant that in looking through the shop manual linked above I cannot find a description of the port from which this water was ejecting. But I'll keep looking.
Rog
Haunting the SBP since 2001
It could be a leaky freeze plug on the back of the engine block...If so... the only way to get to it is to remove the flywheel & bell housing.
Here is the drain tube shown in the Factory Assembly Manual.
Phil
Project Journals
I would do as mentioned above and extend the drain down past the bell housing to exit under the engine. Since there's no change in coolant level it's unlikely the cause is anything other than the cowl drain doing it's job.
Ed
THANK YOU ALL!
