| | | Forums66 Topics128,035 Posts1,055,566 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 14 | I have read about this in the manuals but would like to verify if I am understanding correctly. Are the rear drums on 1949 one ton 3800 trucks the same for single wheel versus dual wheel ? Can the same drum be used for either ? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The online Chev parts manual shows different part numbers for the two models. Parts Book | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | I don't see 2 different numbers for the rear drum in the parts manual, '46-'52 rear wheel drum # 609808. However, the studs are different lengths for the single rear wheel trucks versus the ones that use duals. There is a difference in the front drums for those trucks that have dual rear wheels. | | | | | Joined: Jan 2012 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 14 | Thank you for the replies. I have a chance to buy a rear.drum but it is unclear which set up it s from. As difficult as they are to find I may just go ahead and get it.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | My mistake, that is the rear drum for both single and dual wheel application. I guess I was looking at the front drum. So it doesn't matter which one it was used on. Those drums are super rare so I hope that you are able to get it. | | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Maybe the guys with the parts books can clear this up .... Considering the HO72 axle was used for so many years ('47.2 through '72, right?), then are the drums the same for all those years or do the part numbers change?
I am scavenging brake parts off an HO72 as we speak that appears to have two different era drums on it -- one is ribbed, the other is smooth, yet they interchange. I'm assuming the smooth one is much newer (after the bean counters told the engineers to figure out a cheaper way to make them ...).
Can someone with the parts books take a look at that to see when/if the parts nos change? Maybe the part number only changes when they went from ribbed to smooth, but otherwise the drum is the same? (Two different part numbers, ribs/no ribs, yet fit/function remain identical?)
I was told by competent authority that everything throughout the run of the HO72 interchanges (i.e., that it should be a simple procedure to retro fit the Bendix brakes from a '68, for example, to a '48 -- from the backing plate out). I have not proved this to myself, though. Nor do I know anything about interchangeability between SRW and DRW axles)
Interesting.
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | John, I am pretty sure that the drum changed in 53 when the Bendix style came in. It is interesting that you may have a newer drum. A few years ago I bought a set of drums new for a 38 pickup. They were made in Argentina and they are a one piece cast drum, not like the originals. This causes the center section to be thicker so the other dimensions are adjusted to make it work. | | | | | Joined: Jan 2012 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 14 | Thanks, Truckernix. I was able to obtain the drum. As you say they are super rare. I got it primarily as a back up and will just throw it on the shelf. Keeping on the lookout for another.
I am keeping my truck entirely stock except I made the change to a 4.10 rear end. There sure is a big difference now and it is nice to be able to go around 50 or a little less and not a max speed of 42 mph.
More out of curiosity than anything I did discover a place in Illinois that resleeves old drums. It is nice to know that is an option too. | | | | | Joined: Jul 2014 Posts: 892 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 892 | Vette1968
Would you post the info for the place that resleeves old drums? Or Pm me. 1951 3800 1-ton"Earning its keep from the get-go"In the DITY Gallery1962 261 (w/cam, Fenton headers, 2 carbs, MSD ign.), SM420 & Brown-Lipe 6231A 3spd aux. trans, stock axles & brakes. Owned since 1971. | | | | | Joined: Jan 2012 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 14 | 1 Ton Tommy, I sent you a PM. Not sure about the rules of posting business names here | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Vette1968, posting business names and addresses is just fine if they are already published elsewhere. If it’s a small word of mouth type operation, I would ask their permission first.
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | Doing a search for "brake drum relining or sleeving" should pull up useable results, as well.
