0 members (), 174 guests, and 1 robot.
Topics128,195
Posts1,057,375
Members48,469
Hello All,
I was in the process of changing my rear shocks when I twisted off my rear shock lower mounting stud. This is an original setup so the mounting stud is welded onto the rear axle spring perch plate. As luck would have it I would assume I will be needing the axle U-bolts, a new spring perch with correct lower shock mounting lug and associated hardware. A search on my usual parts source websites has not produced any results. I am finding several conversion options however that is not what I want to do. The driveline is staying original. Anyone have a link to share showing these components for sale? I checked all the usual spots so unless I was searching the wrong terminology replying with "check classic parts" will not be benifitial.
*UNDER CONSTRUCTION*
1953 Chevrolet 3100 1/2 ton-previously abandoned resto.
My Project Bolt
I hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
AD Addict & Tinkerer
I would try posting to the “Truck Parts Wanted” forum and see if some of our fellow “Bolters” have what your looking for.
Phil
Project Journals
Stovebolt Gallery Forum
This might be what you're looking for.
Kevin, That is exactly what I am looking for! YES! thanks!
My Project Bolt
You're welcome. I knew I had seen those somewhere and got lucky on the Filling Station as the source.
