0 members (),
129
Mod | | | Forums66 Topics128,271 Posts1,058,314 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | I am assembling and engine that I have had for a while now. It is a 350 bored .030 over and has been decked to 0 deck height. I am using stock 194 heads with larger springs and 1.6 ratio roller rockers. My question is what length of push rod should I use with this engine. My camshaft has lift of .515"
Thanks in advance. Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
| | | | | Joined: Apr 2000 Posts: 499 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 499 | [img] http://www.compcams.com/Base/Images/Technical/400-200-PushrodDiagramA.jpg[/img] Use a black marker on the top of the valve stem to help you see where the roller contacts. With hydraulic lifters you'll either have to get them filled with oil or change the valve spring for one that is softer than the lifter internal spring. If you're using solids, you don't have to worry about it. I got the image from this web site. web page
'67 GMC 3/4 292 4spd
| | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | To fill the lifters with oil, can I just soak them in hot motor oil?
