3 members (Guitplayer, GMCJammer51, 51 3804), 153 guests, and 3 robots.
Topics128,271
Posts1,058,314
Members48,485
#133095 09/26/2005 4:47 PM
I am assembling and engine that I have had for a while now. It is a 350 bored .030 over and has been decked to 0 deck height. I am using stock 194 heads with larger springs and 1.6 ratio roller rockers. My question is what length of push rod should I use with this engine. My camshaft has lift of .515"
Thanks in advance.
Phil
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
#133096 09/26/2005 10:03 PM
[img]http://www.compcams.com/Base/Images/Technical/400-200-PushrodDiagramA.jpg[/img] Use a black marker on the top of the valve stem to help you see where the roller contacts. With hydraulic lifters you'll either have to get them filled with oil or change the valve spring for one that is softer than the lifter internal spring. If you're using solids, you don't have to worry about it.
I got the image from this web site.
web page
'67 GMC 3/4 292 4spd
#133097 09/28/2005 4:49 PM
To fill the lifters with oil, can I just soak them in hot motor oil?
