4 members (68ironhead, elhippie64, Otto Skorzeny, 1 invisible), 69 guests, and 3 robots.
Topics128,095
Posts1,056,072
Members48,433
I have a technical question regarding the differences between 54 and 55.1 Chevrolet trucks, but in 3600 form. I know that the chief mechanical difference between 3100's of these series is the open drive line, and, if I recall the spring perches moved to the top of the axle housing as well. What are the main mechanical differences for 3604's between 54 and 55.1? Are there any?
3604 is a conventional bed single rear wheel pickup.
Thanks!
1956 GMC 100 NAPCO Deluxe
1955.1 Chevy 3600 NAPCO
1954 Chevy 3600 NAPCO
I know of no mechanical differences.
Professional Novice
Haunting the SBP since 2001
According to the 1955.1 supplement to the 1954 shop manual.... No mechanical changes for 3/4 ton trucks.
Thanks, fellas. I thought this was probably the case, but after losing my library of truck books ( along with everything else ) in the Camp Fire last year... You all were my only available hope of reference! It's much appreciated!
BlueChipper, are you interested in buying a 55.1 3600? I guess I am a little too fond of saying that my first antique Chevy truck was a 55.1 3600 pickup. Many times I wish I still had it. And by the way, 55.1 3100 1/2-ton trucks still had the rear axle above the spring, but without the pivots required for the torque-tube axle.
Professional Novice
