1 members (Hotrod Lincoln),
105
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | There once was a man from Nantucket....
There once was a guy who made adapter plates to fit Stovebolts to engine stands.
Does anyone have a clue if he is still making them or who it is? And have his contact information?
Thanks. Tom
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Most engine stands come with adjustable gizmos to adapt to nearly every engine made. I haven't actually tried putting my 216 on an engine stand, but have no doubts that it could be done with what came with the two stands I have. The length of the engine is a bit of an issue with stability, so be sure you have a stand with 4 wheels.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Super good advice Kevin, any inline engine needs a four wheel stand 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Thanks. I have put GMCs and Chevy 261’s on these stands, and have the stands you refer to, but I get tired of fiddling with it and bolts and a pile of washer spacers. Just might treat myself to a little convenience as I get older and acquire an adapter plate.
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | Tom, I hear you about fiddling with the adapters. If you're working on the same kind of engine all the time, a few well placed tack welds would eliminate the fiddling requirement.
A fixed adapter plate if you can find one would be nice, as you say, but not all engine stand hubs are drilled on the same pattern. That's not an unsurmountable problem either though.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Scott Marshall over at inliners made up a couple of really nice ones but I don't think he has made any recently. His was really nice and I would have loved to have gotten one. If anyone knows Scott and has some contact info for him, we mioght be able to ask him about making a few up. I have a friend who is a race car fabricator who I am going to ask about making one up for me for my stand for 235.261 chevy use. If there is any interest, maybe he would be willing to make a few of them up.
Mike
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | Look how nice that adapter is. I really hope he makes a few up. If he gets back to you and is willing to make a few if he has a minimum of orders we might be able to wrangle enough interest to make it happen.
Mike
| | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Yep. I agree. Will see if he corresponds. Not sure if he is still in business. But, i need two, | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Been thinking about this. An engine stand has 4 arms that are adjustable to various motor patterns. I have a 4 wheel one myself. Don't take this the wrong way, but what is the problem with using the stand? A specific motor stays on a stand for a long time. You don't switch motors every day or week. What does an adapter save you? You have to undo the adaptor and store it away with extra motor bolts and washers? You hold the motor up in the air with a cherry picker, roll the stand up and bolt. 15 minutes. I don't fiddle. The washers stay on the stand with a temp nut. Weld on/bolt on a stick-up bolt/stud to store washers.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I hear what you are saying and I suppose I can keep making due with the adjustable. But I would rather have a nice one that requires no adjusting at all. Just bolt it on. And Scott Marshall’s is as nice as I have ever seen.
Mike
| | | | | Joined: May 2015 Posts: 11,052 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,052 | That does look like a nice setup. I was envisioning something that would bolt on to the plate on the engine stand, but replacing the whole rotating tube section is even better. Don't know, but it implies it would work on ANY GM engine, which would be nice. As far as storing the adapter, that's nearly a non-issue, as it would just stay in place on the stand. You could turn your old rotating tube assembly into a holder for welding rods, or whatever.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I know what you mean, Mike I do things like that. Just wanted to know what the real problem was. The adaptor looks nice.
How about this: The stands have a tube with a plate welded to the tube. Then 4 arms bolt to that plate.
Take off the arms, drill a plate to match the stand plate holes and drill the 216 pattern on that plate also.
It seems like with the Marshall plate, or any plate, there will be washers or spacers to deal with. Not sure.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I think that is right. To clear the crank flange and get the motor spaced out enough to rotate.
Mike
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I hear what you are saying and I suppose I can keep making due with the adjustable. But I would rather have a nice one that requires no adjusting at all. Just bolt it on. And Scott Marshall’s is as nice as I have ever seen. Sorry Mike, I was speaking to Tom, but you answered my post and I got mixed up. This is Tom's post. I see you are helping but you are also answering other helpers. I'm trying to give ideas to Tom.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | My fault entirely. Exuberance over the subject matter! I will sit down and behave, lol.
Mike
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | The crank clearance and fiddling with bolts and washers got me to thinking about the adapter and my interest in it. I have 4 inlines that require work on a stand, so for now and over the next couple years it will work for me.
He returned my email and I am going to have him make one. Feel free to email him - if he is setting up for one he can cut several.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Thanks for the update Tom. Good info.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | Good discussion and points made. | | | | | Joined: Oct 2009 Posts: 164 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 164 | If I’m not mistaken I saw a post a while back where someone took an old bell housing, kept the bolt pattern that went to the motor and used that as the mount to the stand, as I’m typing this I believe it may have been Deve . He also has a web site you can look at. | | | | | Joined: Aug 2012 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 28 | When I did my 261 i used a 61 powerglide adapter to bolt it to the stand.
1954 GMC 9314 - 261 t5
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Scott Marshall here, and these are still available! Several have already contacted me and I am filling orders now, so just give me a week or so and they'll be ready to ship out. Thanks everyone!
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You might want to post a Part for Sale in the Swap Meet? | | |
