1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | I was wondering if 255/60 would be good on 15x7 rims. I have 4 15x7 rims and was wondering if that tire size would be good on all 4 of the rims. What do you all think? These will be going on my 64 chevy truck after i lower it. Going with the 3" coil spring drop in front and 4" in the rear.
Stovebolt-It is painted
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | As a matter of fact, the 255/60R-15 is the size I use on my 1968 Corvette because they are 27" in diameter which is exactly the diameter of the original F70-15 Wide Ovals.
I don't know if they're still available, but Pirelli makes that size in their Scorpion SUV tire with a V-rating. And they are the only company out there that carries this size in something better than S-rated tires that I know of. I got a set of those for the Vette.
Mine are mounted on 15x8 wheels, but you can usually go down or up an inch. It should fit fine.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Oct 2004 Posts: 209 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 209 | yea i was thinkin it would be fine. I might put 245/60 in front and 255/60 in back. But to save money for now i might just put the tires i have which are 225/75 on my 15x7 rims. I dont know yet though. thanks alot for the help
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I've got a set of 255 60 R15s on a set of 6 1/5" rims that I havn't put on my truck yet 'cause I'm in the middle of a rear diff swap. Read somewhere the other day that minimum rim width should be 7 1/2"
