Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Otto Skorzeny, NJC), 109 guests, and 1 robot.
Topics128,277
Posts1,058,453
Members48,490
#1330062 10/15/2019 11:30 PM
Trying to ID my SM420 transmission so I can buy new parts...
the Novak-Guide says that '64-67 transmissions have a 7 digit casting number with aluminum 2nd gear synchro and identical 3rd & 4th synchros
My transmission has a 7 digit casting code, however, the date code ends with a 9 (indicating 1959)
The 3rd and 4th synchros appear to be identical, but my 2nd gear synchro cone & teeth appear to be steel rather than aluminum.
So maybe the novak guide is wrong & they actually used 7 digits in 1959?
Or maybe I have a '64-67 transmission where they screwed up the date code?
Doesn't seem like my 3rd and 4th synchros should be identical if there are steel parts for 2nd gear synchro rather than aluminum?
What is happening here?
'59 Chevy Suburban, NAPCO
Ott3r #1330067 10/16/2019 12:19 AM
Ott, they are talking about the friction material (aluminum vs steel) that is housed within the first gear. This is what is used to slow the 2 nd gear syncro ring. I have only ever seen one that was worn enough that warranted replacement out of a dozen or so transmissions that I have worked on this last year. As far as I know the friction material is unavailable by itself necessitating replacing the entire first gear if needed.
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Whoa, you work on a lot of transmissions!
Thanks for the distinction... mine does shift nicely into 2nd and the friction material (within 1st gear) is bronze.
I'm mainly needing to replace the 3rd gear synchro and am debating to do the bearings while i'm at it.
Present bearings 'seem' ok and are labeled 'New Departure' made in USA
Logan
Yes excuse my typo, most are bronze. To replace the 3rd synchro you will need to remove the clutch gear and press the rear bearing off the main shaft to get the gear cluster out of the case. The hub will need to be pressed off the main shaft to get to the 3rd synchro. Occasionally they pop up on ebay. There is one in there now
https://www.ebay.com/itm/1948-1949-1950-1955-chevrolet-4-spd-truck-1st-gear-countergear-nos-gm-591602/123819292750?hash=item1cd434784e:g:PRwAAOSwV4xcu31W
cheap enough
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Anyone have a 4-speed yoke for 1/2 ton torque tube? I need one for my Muncie 420.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
