| | | Forums66 Topics128,081 Posts1,056,073 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2018 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 22 | Trying to verify the correct gauges as far as speedometer, 80 or 90, and oil pressure, 30 or 60. I thought I read it somewhere on here but can’t seem to find it. Not sure if it matters but this is for a 1 ton truck | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Do you have the stock tires and rear end? I don't so I've gone through a neighborhood speed measurement device and have recalibrated in my mind.
I don't think you need to recalibrate oil pressure. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2005 Posts: 155 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 155 | The 1950 speedometer should read 80mph. (90mph speedometer is introduced in 1952 half-ton) Oil pressure gauge should read max 30 for all 216 and babbitt 235 engines - which your truck originally would have had. | | | | | Joined: Dec 2018 Posts: 22 'Bolter | | 'Bolter Joined: Dec 2018 Posts: 22 | I was told the engine that is in it came out of a 54. Does that mean I will need the oil gauge that reads 60 psi to work correctly? | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | If the gauge cluster is currently out of the dash, it would be easy enough to swap in a 60# gauge into the cluster. If it is still in the dash, I wouldn't bother taking out the cluster just to switch to the 60# gauge. The 30# gauge will work just fine with a '54 engine. It will peg the needle on 30# while driving, and somewhere below 30# at idle when fully warmed up. I am more concerned about the low end range of oil pressure rather than the high end, so I stayed with the 30# gauge on my '49 with a 350 in it. Pegging the 30# pound gauge will not harm the gauge whatsoever. Carl
