2 members (stlcardinalsguy, PAUL Berardi), 134 guests, and 2 robots.
Topics128,081
Posts1,056,078
Members48,434
#1330079 10/16/2019 1:27 AM
Trying to verify the correct gauges as far as speedometer, 80 or 90, and oil pressure, 30 or 60. I thought I read it somewhere on here but can’t seem to find it. Not sure if it matters but this is for a 1 ton truck
Do you have the stock tires and rear end? I don't so I've gone through a neighborhood speed measurement device and have recalibrated in my mind.
I don't think you need to recalibrate oil pressure.
The 1950 speedometer should read 80mph. (90mph speedometer is introduced in 1952 half-ton) Oil pressure gauge should read max 30 for all 216 and babbitt 235 engines - which your truck originally would have had.
I was told the engine that is in it came out of a 54. Does that mean I will need the oil gauge that reads 60 psi to work correctly?
You might as well ID your engine.
find and post the codes shown on this page
If the gauge cluster is currently out of the dash, it would be easy enough to swap in a 60# gauge into the cluster. If it is still in the dash, I wouldn't bother taking out the cluster just to switch to the 60# gauge.
The 30# gauge will work just fine with a '54 engine. It will peg the needle on 30# while driving, and somewhere below 30# at idle when fully warmed up. I am more concerned about the low end range of oil pressure rather than the high end, so I stayed with the 30# gauge on my '49 with a 350 in it.
Pegging the 30# pound gauge will not harm the gauge whatsoever.
Carl
