Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (NJC, tclederman, moparguy, GRNHydra, Wayne67vert, 78buckshot), 57 guests, and 1 robot.
Topics128,009
Posts1,055,293
Members48,419
#1330029 10/15/2019 6:33 PM
Can someone check this number for me. It is on the boss behind distributor
O 363508T56Z
Thank you in advance
mo2cyl #1330036 10/15/2019 7:48 PM
Check out this website for help....
http://devestechnet.com/Home/CastingNumbers
mo2cyl #1330039 10/15/2019 8:11 PM
You will need to post more codes from you engine in order to ID it.
Deve's information get you close to a "definitive" ID.
Post the head/block casting codes and date codes.
mo2cyl #1330056 10/15/2019 10:53 PM
Thanks for the responses
mo2cyl #1330075 10/16/2019 1:11 AM
I believe the first letter/number is actually a zero, not an "O"...there should be 7 numbers before the plant letter.
So, here's the way your number breaks down.
0363508T56Z
0363508 = unit number starting with 0001001
T = Tanawanda engine plant
56 = year (1956)
Z = Regular 235 6-cylinder with a 3-speed from a passenger car
You have the 362,508th type "Z" from Tanawanda.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
mo2cyl #1330098 10/16/2019 4:14 AM
Thanks Mike!
