5 members (Gdads51, KEVINSKI, dt235sd, Peggy M, 1 invisible), 175 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
#1329745 10/13/2019 4:34 PM
So, I started up my engine yesterday and it seemed to be running a little rough. Climed out and opened the hood while it was running to check things out and gas was running out of the side of the carb! I quickly shut it down, and it took a good couple of minutes for the gas to stop leaking out.
Went back this morning, the fuel filter was empty. Pulled the top of the carb off to check it out, found that the measurements for the floats were off. I got them back to where they should be, put everything back together, started it up and no problems.
So...how could the float settings have changed? It was running fine before this, and had been for several months. It's good now, but I am still mystified.
Tim
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
bluesman #1329763 10/13/2019 7:01 PM
Carburetion specialist
The Carburetor Shop
bluesman #1329770 10/13/2019 8:02 PM
Well, I suppose it's as good an explanation as any. Not very satisfying, though.
Tim
Tim
bluesman #1329780 10/13/2019 9:34 PM
Tim - do you have a Carter YF?
If so, possible to put the float pin in backwards. Over time, the free end will back out, and the float will wobble, making the settings wrong.
Jon.
The Carburetor Shop
bluesman #1329800 10/14/2019 12:23 AM
I have a Rochester B. Brand new (well, only has about six hours on it). And it was running so well before this happened.
Tim
Tim
bluesman #1329802 10/14/2019 12:28 AM
Stuck float needle
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
bluesman #1329829 10/14/2019 3:28 AM
I thought about that, and while I had it apart I checked the needle valve. I seemed to work fine, although it seemed to stick a little bit in the closed position. But that would cut off gas to the carb, not flood it. At least I think that would be the case.
Tim
Tim
bluesman #1329830 10/14/2019 3:47 AM
Insomniac
Insomniac
Did you shake the float to make sure that it doesn't have gas in it?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
bluesman #1329837 10/14/2019 5:09 AM
B floats are prone to contacting the side of the bowl if they get bent. The rebuild instructions warn of this.
The old 'hit the carb with a hammer' trick is commonly used to temporarily fix this problem until you have time to fix it right.
This might explain why the problem came and went on its own. For now anyway.
bluesman #1329886 10/14/2019 4:41 PM
Yes, I checked out the floats for floating, that was my first thought. I also checked for binding, followed the rebuild instructions for testing for hitting sides. I guess this will just end up being one of those "don't know what's goin' on" things. At least I'm back to running. With luck I'm going to get the truck inspected tomorrow so I can get plates on it.
Tim
Tim
