2 members (Gdads51, MarkT), 134 guests, and 1 robot.
Topics128,078
Posts1,056,022
Members48,433
#1329672 10/13/2019 12:18 AM
I was wondering if anyone knows if the cab overs would have more of a flatter fan then the other trucks,a local junkyard has a couple and might grab them if they could be used on earlier trucks to get a the fan away from the radiator so fan belts can be changed easier,
Per my 1951 Parts Book...1.064
1939-51 ALL COMM and UTIL....18" dia., 4-blade fan....839020
1937-51 ALL UTIL (For low speed operation)....18" dia., 6-blade....604225
Looks like they all used the same fans...nothing special about the COE's.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I have a 49 to 54 car fan on my 37 p/u and have less then a 1/2 inch from the radiator so I picked up a original 37 fan that looks like it will be closer to the engine then what is on it and have enough room to change the belt,the 37 fan will be going on when I change the engine but the COE fan looks different then the same era car fan and might grab them while the getting is good. The COE fan looked to be around 5/8 from the radiator where a same era GMC conventional was over a inch but could not find a same era Chevy to compare,should have used a truck fan when I put the water pump adapter on my 57 235 but thought they were all the same at that time.
