2 members (mick53, J Lucas), 133 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
Is it necessary to remove a master cylinder in order to rebuild it?
There is only a very slow leak at the from of the MC, and otherwise has been working great.
Roger Schroeder
1951 Chevrolet 3600.
It’s not usually necessary to remove master or wheel cylinders to hone and rebuild them.
Sometimes better to leave them installed if removing might lead to more work than you’re prepared for.
Alternatively often easier to just remove them and work on things on the bench and get a better view.
•1952 Chevrolet 3800 pickup
---All pictures---
AD Addict & Tinkerer
Assuming we are talking about a below the floor master cylinder, I just removed mine in about 15 minutes on my 52’ 3100 to rebuild it. After cleaning and honing, I decided to replace it due to corrosion in the bore that I could not remove. I don’t think I would have seen the issue with the master cylinder installed. I also can’t fathom performing all the work involved in the rebuild lying on my back. In addition, the back of the master cylinder is only a few inches from the rear transmission crossmember so honing it would be near impossible.
I second Grigg’s suggestion to remove and work on the bench. Your back will thank you
Phil
Project Journals
Stovebolt Gallery Forum
Fox Offline
Anyone know where a guy can get s dust cover rubber boot for the pushrod plunger? I have nalresdy replaced the interanls, but now can’t find the dust boot independently to complete the rebuild.
Sorry to hijack...😜
I vote remove it as well. Working on your feet is so nice; plus you don’t have dirt falling in your eyes (or your new cylinder!).
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I try to work sitting down whenever possible. Even nicer than working on my feet. thumbs_up
I removed my MC after the cab was off so didn't have to worry about the dirt.
Quote
You should find what you need on one of these sites.
TRY HERE
Ebay
Steele Rubber
Harold
Harold
You can buy it at Classic Parts but shipping is $9.95 minimum. Do you need anything else?
https://www.classicparts.com/1947-72-Master-Cylinder-Boot-Manual-Brake/productinfo/71%2D285/
Phil
Project Journals
Sir Searchalot
Sir Searchalot
Morerog: I have never even thought of doing it on the truck so don't know how hard it is. I've only done it on the bench.
could not do a good inspection, ream job, parts insert job or bleed job lying under the truck. It's the brakes you know.
Hijacker:
Most, but not all, of the parts at Steele are American made with American rubber. They will last way longer than all the other off shore pieces. Email them to see if this boot is made in USA. If not, the cheaper ones may be from the same source*. If made here, buy that one.
Steele used to be 100% American made parts. I guess they had to compete with some parts or not enough demand to build tooling. Anyway, they still make most at their factory.
* Their site says they buy some parts from outside vendors who buy from off shore.
