8 members (Otto Skorzeny, Shaffer's1950, SlimSix, Hotrod Lincoln, TrknGMC, homer52, 2 invisible), 79 guests, and 2 robots.
Topics128,139
Posts1,056,451
Members48,441
I just completed a big project. I'm documenting how to remove, disassemble, rebuild and finally reinstall a 1963 C10 manual transmission steering column. The 1964 - 1966 columns are identical except for the turn signal mechanism.
My 1963 column needed a rebuild so I thought I'd add some pages to my website.
I'm not an expert, so if you see anything that needs editing or a better explanation, please let me know.
I'm most proud of the 1963 Chevy C10 Steering Column Rebuild page. Nice clean parts always make for better pictures.
Here are the links to the web pages.
1963-66 C10 DIY Steering Column Page - LINK
1963 Chevy C10 Steering Column Removal
1963 Chevy C10 Steering Column Disassembly
1963 Chevy C10 Steering Column Installation
Nice project and page. Thanks for sharing with us Jay.
~ HB
1962 Chevrolet C10
1962 Suburban
Thanks for posting, looks like a lot of great information. I'll be rebuilding my '63s column as well here in the near future, and it'll be nice to have something to go by. If memory serves, there isn't much, if anything, on steering column in the factory service manual.
Cedric L. Brown
1963 Chevrolet C-10 long stepside
[url] https://photos.app.goo.gl/hE3wcWiY5FENFwfK2 [url/]
If your column is in decent shape then the rebuild is not difficult.
One thing to consider is to upgrade the lower end of the shaft to a safer telescoping shaft.
I highly recommend it and especially if you plan to install power steering.
This LINK shows the details of what I did on my 1965 truck. I have all the pieces to do the same with my 63 steering and hope to complete it by December.
Good to know. I'm not currently planning to install power steering, but the telescoping column sounds like a really good idea. Thanks again!
Cedric L. Brown
The telescoping shaft modification can be done on any shaft, factory or upgraded to PS.
Hello, would anyone know if this rebuild explanation will work on a 62 steering column or is there a big difference.
Great job. I replaced the bearings on my 60 when replacing the steering box. Turn signals work but I can't get my horn to work. I installed an aftermarket "button" I have attached to the floor shifter many years ago for the horn but would like to the horn to work as intended with the original horn button. Can anyone help? The small springed button inside is new. The wire is hooked up and runs down and exits the column under the dash. I just don't what to do with that single wire. I'm brain dead when it comes to wiring. Thanks in advance.
Mark
Mark
The 1963-66 columns have a ground wire from the horn relay to the steering column horn button contact ring. When you press the steering wheel horn button you are connecting that ring to ground to complete the circuit. That trips the horn relay to supply current to the horn.
Start at the horn relay. Connect the relay to ground. The horn should sound.
Then confirm wire continuity from the relay to steering column either by grounding the column horn wire (horn will sound) or with a multimeter.
If the column horn wire sounds the horn when grounded, you must next confirm that pressing the steering wheel horn button communicates that connection to ground.
Thanks I will give it a go. Hopefully my 60 is the same.
Socket Breaker
Socket Breaker
awesome content Lugnutz, thanks for creating and sharing.
-Woog
-Woog
The 4 part steering column DIY is done. 1963-66 C10 DIY STEERING COLUMN PAGE - LINK
