0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
I'm in the process of refurbishing my doors for my 48 Chevy 1/2 ton truck. It looks like my original door window stainless steel trim has never been off. If I can remove and replace it without damaging it I would like to remove it to make sure I have no rust behind the trim. I welcome your advice. If I stand to damage the trim I may just carefully tape around it so I can prep my doors for paint. Thanks in advance for your advice.
Go HERE
Scroll down to [Entry #10] Removing Window Molding- Front Doors
Read, then (click photos to enlarge)
or
Photo 1
Photo 2
Photo 3
Should be fairly easy procedure.
Note: The photos are from a 1954 truck which came with vent panes. I assume your 48 does not have vent panes.
The doors that have a vent pane, the stainless steel trim is cut slightly different to accommodate the vent pane frame.
I believe both are attached to the door the same way.
Thanks for the photos and the info. I appreciate it.
