3 members (Guitplayer, Patina 54, Steelonsteel), 42 guests, and 2 robots.
Topics128,035
Posts1,055,441
Members48,422
#1328837 10/05/2019 1:53 AM
Got power one side but not the other what does it do truck won’t start
TPR57C #1328841 10/05/2019 2:20 AM
It makes it start, mate. smile
The ballast resister reduces the voltage from 12 volts to around 9 volts to protect the points from excessive pitting.
They go bad.You need a new one.
I keep a jumper wire with alligator clips on the ends in the glove box for just such emergencies. You can use it to jump across the ballast and provide voltage to the coil so that you can get to the parts store, or back home, or in my case one time, through the 17 mile long Chesapeake Bay Bridge Tunnel.
Carl
TPR57C #1328842 10/05/2019 2:25 AM
I had to chuckle Carl, that would be a nightmare stuck on the bay bridge, I remember going through it as a kid right after it opened in the early 60s, popped up in the middle of the atlantic and couldnt really see land, but you are on a road, wow.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
TPR57C #1328921 10/05/2019 8:56 PM
Solenoid on starter was stopping from starting swapped it with old starter I had and then success now I know what resistor does thanks
