3 members (JW51, 48JimC, Forty9),
115
Mod | | | Forums66 Topics128,092 Posts1,056,457 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I'm just about finished building my 261 to stick into my '51 1/2 ton and therefore am ready to take it to the exhaust shop. I'll be running Fenton's, an X-Pipe and duals.
I've read a variety of differnt suggestions on pipe diameter and muffler choice, so I'd love some input that everyone can refer to later.
Diameter: from header to x-pipe to muffler and muffler to tip? I've heard a variety of things. Someone told me to keep it 1 5/8" between the header/x-pipe/muffler and run 2" after that in order to build up enough back pressure and efficiently scavange with the x-pipe which should be located within a foot or two of the header outlets. Lots of people seem to like the flow masters, but which one? 40, 60, 70?
I'm torn between going 2" from the fenton's all the way back and doing the narrower pipe in the front.
Any thoughts?
| | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | Also, how about routing? Patrick's exhaust kit runs them 'shotgun style' side by side all the way back.
Does anyone have any pictures/suggestions on routing the pipes, locating the mufflers and x-pipe?
I've got a booster/dual master, t-5, 10 bolt posi (3.42:1) and plan to add a trailer hitch. So, I'm definately going to have the pipes come out just behind each rear wheels.
What about using resonators in addition to the flow masters?
| | | | | Joined: May 2005 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: May 2005 Posts: 50 | 40 series = Loud+resonance(original flow masters) 60 series = Not as loud, still resonates a little 70 series = A lot more tame less resonance
If you run them back together you'll have to cross over with one at some point...in my opinion that looks cheesy. I think it looks better with the pipes ran on opposing sides. Later
Dave
Even a blind squirrel gets a nut sometimes!
