| | | Forums66 Topics128,036 Posts1,055,452 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2012 Posts: 842 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 842 | Got power one side but not the other what does it do truck won’t start
| | | | | Joined: Mar 2010 Posts: 10,271 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,271 | It makes it start, mate.  The ballast resister reduces the voltage from 12 volts to around 9 volts to protect the points from excessive pitting. They go bad.You need a new one. I keep a jumper wire with alligator clips on the ends in the glove box for just such emergencies. You can use it to jump across the ballast and provide voltage to the coil so that you can get to the parts store, or back home, or in my case one time, through the 17 mile long Chesapeake Bay Bridge Tunnel. Carl
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | I had to chuckle Carl, that would be a nightmare stuck on the bay bridge, I remember going through it as a kid right after it opened in the early 60s, popped up in the middle of the atlantic and couldnt really see land, but you are on a road, wow. 1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jan 2012 Posts: 842 'Bolter | | 'Bolter Joined: Jan 2012 Posts: 842 | Solenoid on starter was stopping from starting swapped it with old starter I had and then success now I know what resistor does thanks
