3 members (1955 1 Series, 2 invisible),
128
Mod | | | Forums66 Topics128,195 Posts1,057,370 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | My old '51 recently stripped some teeth, apparently, and I'm in need of a new gear (which I've found at a few places) and from what I've been told, a new cam shaft would be in order, too. I don't want to put in a piece of junk for a shaft, so I'd like to know where anyone on this forum has found a quality shaft and gear for their 235. Although the engine is a 1956, I'm curious as to exactly what years of this engine have identical parts in this department. But also, and even better, would be someone leading me to a good set of gear/shaft for my truck. No Chinese junk, please. I don't want to have to do this again in the next 10 years. This is my daily driver. Thanks! Lee
"When I rest, I rust" 1951 3100 5 window w/ '56 235
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | Take your camshaft and send it to delta camshaft in Tacoma Wa for a regrind. Also if you have solid lifters,send them too, so they can machine the bottoms for the regrind, run you only about $150. They will also sell you a quality timing gear setup too. I have been using them for 40 years. Cam cores are getting scarce so they might not have an exchange necessitating you sending yours in. http://www.deltacam.com/
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 |
Mike
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Before tearing out the old cam I would check the lift of each lobe with a magnetic base dial indicator. If each gives a lift of 0.404 then it's not worn and if the lift is not down then the duration will be right also. We have a solid lifter with a push rod brazed to it to make checking easier than trying to work through the side cover opening.
Evan
| | | | | Joined: Nov 2014 Posts: 623 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 623 | Thanks guys! These ideas will help out, and I appreciate them. Thanks for the tip on delta cam, sstock.
