5 members (J Lucas, Lugnutz, Otto Skorzeny, Steelonsteel, Rich'sToys), 94 guests, and 2 robots.
Topics128,211
Posts1,057,472
Members48,473
My old '51 recently stripped some teeth, apparently, and I'm in need of a new gear (which I've found at a few places) and from what I've been told, a new cam shaft would be in order, too. I don't want to put in a piece of junk for a shaft, so I'd like to know where anyone on this forum has found a quality shaft and gear for their 235. Although the engine is a 1956, I'm curious as to exactly what years of this engine have identical parts in this department. But also, and even better, would be someone leading me to a good set of gear/shaft for my truck. No Chinese junk, please. I don't want to have to do this again in the next 10 years. This is my daily driver. Thanks! Lee
"When I rest, I rust"
1951 3100 5 window w/ '56 235
Take your camshaft and send it to delta camshaft in Tacoma Wa for a regrind. Also if you have solid lifters,send them too, so they can machine the bottoms for the regrind, run you only about $150. They will also sell you a quality timing gear setup too. I have been using them for 40 years. Cam cores are getting scarce so they might not have an exchange necessitating you sending yours in.
http://www.deltacam.com/
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Excellent advice!
Mike
Before tearing out the old cam I would check the lift of each lobe with a magnetic base dial indicator. If each gives a lift of 0.404 then it's not worn and if the lift is not down then the duration will be right also. We have a solid lifter with a push rod brazed to it to make checking easier than trying to work through the side cover opening.
Evan
Thanks guys! These ideas will help out, and I appreciate them. Thanks for the tip on delta cam, sstock.
