| | | Forums66 Topics128,090 Posts1,056,031 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | I need a core support and it looks like a new reproduction is my only option. Am concerned about quality and fit, has anyone bought one? If so from what supplier and how pleased where you with it?
ESum
| | | | | Joined: Feb 2002 Posts: 2,893 Socket Breaker | | Socket Breaker Joined: Feb 2002 Posts: 2,893 | well, you could stop into the swap meet "parts for sale" and "parts wanted" here in the swap meet section of the stovebolt page as well. -Woog | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I used a repro core support. It fit fine. Some tweeting and prying but nothing I did not expect. I dont recall which vendor I used. I have also had good luck trolling ebay and CL for parts - if you are looking for the original. | | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | Thanks for the reply, I will search for a used original but I suspect they all rust in the same spot as mine under the battery.
ESum
