| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Did you try an Internet search?It looks like a lot of Chinese companies? | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | If the cokers are white walls just turn them around. Just continue to do a search, should be out there somewhere.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Possum, I believe the wheels your friend gave you are hub pilot wheels which won't fit your hubs correctly, you will have to find some 22.5" Budd wheels and swap the tires over. | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | I have, and I noticed that. Never bought a Chinese-made tire before so I don't know how trustworthy they are. | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | If the cokers are white walls just turn them around. Hmm, sounds like a waste of money. | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | Thanks Mike  I'll check em out! | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | Hy Possum, I believe the wheels your friend gave you are hub pilot wheels which won't fit your hubs correctly, you will have to find some 22.5" Budd wheels and swap the tires over. Didn't think of that! Though I'd like to test fit one just to make sure. | | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | i also recommend the Samson tire brand, they are made for working, i have a set of 4 on my one ton and hauled gravel until i was nearly bottomed out on the auxiliary leafs the coker tires are for show only, they would fail if you tried to use them for actual work -s | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I have Samsons on my 630, not many miles, but work OK.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'll second that the modern hub piloted wheels are not a replacement for your stud piloted wheels. Even if the bolt pattern is similar the wheel won't be supported to run true or carry the load as intended. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Wow!, I'd love to have a set of those 10.00x20, U.S. Royal gangster whitewalls, on my COE, but $1300ea., is a bit much. | | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | Thanks guys, looks like I'll be on the hunt for some stud piloted wheels. Plus I still need to go by the tire shop and see if they'll work on these original Budds. | | |
