2 members (Southerntruck, TooMany2count), 72 guests, and 2 robots.
Topics128,089
Posts1,056,116
Members48,434
#1328413 10/01/2019 6:32 PM
Just finally picking through the to do list on the project truck and the gauges are next. Got speedo working well and gas gauge and oil pressure all set...... but i could have swore the temp gauge had a cut capillary tube but i was wrong! Its a electric gauge. Does anyone know what the oem resistance values were for the stock sender? The gauge seems fine but with all the research i have done i keep getting totally conflicting info. Any insight on this would be greatly helpful. **** im not concerned with the thread size or where it goes because this is a custom setup but i just need to figure out the factory resistance values***
Thank you.
Easy problem to solve. Use a variable resistor around 0-100 ohms. One lead to wire to gauge, other wire to ground. Key on. Vary resistor till you peg both ends of gauge. Read resistance of the resistor at both 0 and full scale and you have it. Problem is getting parts person to sell you the sensor when only knowing the resistance value.
Sir Searchalot
Sir Searchalot
Seems like you should have a mechanical gauge on a 49? If so, then you are going rogue and the gauge is not stock. If so this would work with no fuss on any motor in the galaxy.
If you have an electric temperature gauge in the cluster, classicparts.com has what you need. It is part# 53-811A. $24.95. It is for '57-'78 trucks. The write up they have for this part is pretty lengthy and sounds like it will work for your application.
Carl
Its a stock gauge. Some gmc’s had electric gauges from what I have read. All chevys had the capillary tube type senders.
Sir Searchalot
Sir Searchalot
OK, good to know. When I searched I got a mechanical gauge for 1949 GMC. Click.
Ive seen talk of it in a few places.
Read 5 or 6 post down and they are talking here on it.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/102491/temp-gauge-problems.html
You are correct. That would be the scientific way to do it! I was hoping someone just knew off the top of their head what they were. Like the common fuel gauges that most remember.
I posted the link above
