| | | Forums66 Topics128,105 Posts1,056,543 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | For a '48 1Ton Dually. Is it OK to jack the front wheels off the ground by lifting in the middle of the axle? My big bottle jack has a small lifting pad but I have a 4" square of 1/2" thick steel that I can use to help spread the load. It would make setting the jack stands a lot easier and faster than doing one side at a time. | | | | | Joined: May 2015 Posts: 11,105 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,105 | The point load on the small lifting pad isn't really an issue. Putting a loose steel pad would probably not be a good idea, as it increases the chance of the axle slipping off the jack. The more concerning thing would be bending load on the axle. That being said, I really doubt that it would hurt the axle, just not a really good idea. I would jack up one side at a time and put a jack stand underneath.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Kevin, thanks for the response. I didn't think it was such a hot idea but would have been pleased to find out that it was! Anytime I can cut my 'under the truck in the gravel time' down I'm a happy man. | | | | | Joined: Feb 2000 Posts: 5,226 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,226 | We lift heavy trucks and school buses from the center of the front axle all the time at work. I lift my '37 from the center also, the axles are much stronger then you think. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Some axles are strong, some less so.
I’d lift a 1/2 ton at each spring, not at the center. | | |
