3 members (klhansen, dt235sd, 1 invisible), 67 guests, and 0 robots.
Topics128,049
Posts1,055,679
#1326954 09/20/2019 7:43 PM
I don't know if this is the place to put this, but I thought others might find it helpful. If this is the wrong place feel free to move it.
Tim
SHA1: a5ef102dc4aea09e6116d1b825ec2f82321ed413
I am currently digging back in to a 1953 3800 (one ton) with a nine foot bed. I've owned it since 1979, and drove it until 1982 (or so). My wife got me involved in restoring it back in 2002, got the body removed and the frame redone, then things came up. Now I am retired and starting again. If anyone is interested I have photos on Imagur ( https://timwhiteblues.imgur.com/ ). I live way back in the woods in the Ozarks on 40 acres at the end of a 2 1/2 mile private road.
Tim
Where exactly do you buy a bed to assemble? Or is this period correct? I cant seem to find a 9 foot anywhere, aftermarket, new, used, or even scrap for that matter.
It seems that no one makes reproduction sides for the one ton bed. I managed to find a good set several years back from Jim Carter. And I think that Mongo had a set llast time I was at his yard.
Other than that, the front panel, cross sills, wood, and tailgate are available from MarK, and also Jim Carter (which is where I got mine.
I guess there simply aren't enough one tons out there to make it worthwhile making reproduction sides.
Tim
Tim
Or the sheet metal cutting and forming machinery they have available can't handle 9'. I never asked but that's my guess.
They do make the other 1 ton specific bed parts as mentioned, so there is demand for 1 ton bed parts to some extent or they wouldn't even make those.
1952 Chevrolet 3800 pickup
---All pictures---
According to Mark (former owner now consultant) at Mar-K there isn’t enough demand for them to build the 9 foot bed sides.
There was a post a while back about a guy who built bed sides (don't recall what size they were) using exhaust tubing for the roll at the top. If a guy had access to a big enough brake to make bends in a 9' sheet of steel, a set could be built. I'm assuming that the stake pockets are the same as the short beds, which would be available from Mar-K or other vendors.
Well id like to find em or a complete bed if any1 runs across 1. I currently have nothing yet. Might have togo flatbed style, but dont want to invest in the time and money then find an actual bed that id rather have anyhow.
Fox Offline
The stake pockets are the same. However, I used pockets off of parts trucks. I did what Kevin mentioned above with my one ton building my own and it worked out very well. I built the bedsides, front panel, a couple cross sills, the rear cross sill, the running boards and fender extensions. I was able to use a huge brake at the shop where I was building rigs at the time. Those 9’ long welds took a lot of metal working to get smooth!
Would I do it again?
Yep. It’s going way faster this time around...that is, when I’m able to actually have time to work on trucks! Two little ones under 2 years old make it harder to find time!
I’m almost completely done the 1/2 box. I just have to plane and router the bed wood and it’s completely “roughed out!”
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1107350/1.html
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
Question? Is a 9 foot bed the same, single wheel or dually, with different fenders?
Fox Offline
Duallies didn't have boxes. They would have been a cab and chassis option, and would have come equipped with a grain box, stake bed, or flat deck from a dealer. I hand built my nine foot pickup bed with flared running boards to accommodate the extra width.
Fenders would only come on a single wheel rear box as that was the only option.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Hmm. learn something new everyday... No wonder I cant find one.....
If I'm not mistaken they did have a dually in the 30's or 40's with a 9' pickup bed.. I could be mistaken.
For sure the 48-54 9 ' pickup beds were only single wheel (from factory).
---All pictures---
I guess nuttin in the late 50s early 60s then?
Fox Offline
That would be so cool to see one of those 30/40 dusllies. I never knew that. Might have to do some inter web surfing here.
I think a guy has to get into the late 60’s for dually box/fender. Maybe the ‘70’s?
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
I once saw a late 30's dually in a yard with a box. The running board extensions flared to meet the simple wide rolled rear fenders. I assumed it was a one of custom and it's haunted me ever since. Rather than fabricate 9' sides, I thought it may be easier to purchase a third side and add on to stock length sides with the seams under stake pockets.
Fox Offline
So a super long box? That’d be pretty neat.
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Yeah, the long box is one of the neatest things on the truck. When I was still driving it (back in 1980) I needed some gravel for my road, so I drove down to the local gravel guy and asked him to load the back up for me. He dumped a full load from his front end loader, looked at it and said "you can take a little more" and dumped another half bucket in. The over load springs were nearly flat, and the rims were about 2" from the road, but it hauled it back. Of course I drove pretty slow, and the steering wheel had only a minor effect on where I was going, but...
And after living with pickups with 6' beds it will be nice to haul a 4x8 sheet and have it all inside the bed.
Here are a couple of photos of the ruck and bed.
First is the truck yesterday afternoon after the latest shakedown cruise.
Second is the bed assembled sitting in the shop on saw horses.
Third is the bed just after installation on the truck.
Last one is the support from the big bumper to the bed side.
Tim
Tim
62401
FWIW, here's a truck we saw at Macungie (PA) a few years ago. It appears to be a 1.5-ton, but still shows how they did the bed to accommodate the duellies. I don't think the outer fenders are factory wink But interesting to see the inner fenders (which might be factory).
I can't tell you anything about the truck. I just saw it in the for sale corral and took the pictures.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
More ideas for me. Thanks. Im trying to avoid getting a flatbed. Would really like a 9 ft box.
62401
Also, here's a shot I took of Jim Carter's beautiful 1946 1-ton duallie. Looks like regular rear fedners attached to extensions. The running boards are wider at the rear to accommodate. I'll see if I can find the rest of the pictures I took on that shoot.
Another thought is to take one of those low sided towing bodies...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Rustbucket Ranch
Rustbucket Ranch
Seeing all these pics makes me want to built a long bed dually! big_eek
1949 Chevy 3100 (In the family since new)
1955.5 Chevy 3100 - in the DITY Gallery - (Dad's truck)
1955 Chevy 6500 - in Big Bolts - (Possible parts truck?)
1958 Chevy 3800 w/9 ft bed - in Project Journals - (Current project)
1959 Chevy Spartan 10400 - in Big Bolts
Sweet. Any pics of 60s dually beds around?? Or what ever year beds on early 60s dually trucks??
Fox Offline
https://www.rtechfabrications.com/the-ponderosa
Check out the Ponderosa! I myself am a Duke fan. 🤤
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Wow is an understatement...…. The custom work is utterly amazing. Not to mention the price tags. Lol I have enough trouble welding in a basic patch panel let alone coming close to even park in the same area code as any of those.. drive
62401
Those are very nice. I wonder how many they've actually sold?
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Good question. Who has that kinda money? Especially for a truck..But they are way cool
All I can say is “WOW”!
Moderated by  Dusty53
