1 members (tesa),
59
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | I have a '53 chev 1 ton flat deck pick up. Top speed 70km/hr (45mph for my US buddies). I figure I have 2 ways to go with this. Either a) start at one end, and replace the front suspension, rear end and work on everything in between, or b) mount the cab on a newer chassis. Anyone have any strong opinions / ideas on which wasy I should go.
If I go with b, any suggestions on what to use as a donor chassis ( have access to an '86 S-10, but is that too small?
Ian Horner
| | | | | Joined: Sep 2004 Posts: 148 Member | | Member Joined: Sep 2004 Posts: 148 | do you haul with this truck? i would opt for changing out the rear end and either clipping the front, or go with a drop in unit like the wide-ride ifs
2003 ford lightning 1959 chevy 36
| | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | i don't know about the 50's trucks but i have heard of people using a camaro front clip for handling and to add power stearing | | | | | Joined: Dec 2002 Posts: 40 Junior Member | | Junior Member Joined: Dec 2002 Posts: 40 | My 50 3100 sits on a 69 Chevelle chassis, ride and handeling are good. Nothing fancy, just a daily driver... | | | | | Joined: Mar 2005 Posts: 637 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 637 | The Camaro front clip works fine, but the tires rub the fenders when turning. For fender clearance you should use shorter A arms. Scotts in Ventura, Ca. has the arms, they work fine. A friend with a 1957 used them and it was good, also on an A.D. truck. | | | | | Joined: Aug 2005 Posts: 4 Junior Member | | Junior Member Joined: Aug 2005 Posts: 4 | You could put it on a vette chassis like I'm doing to my '61. Here's a link (click on 61 C5 PU) http://photobucket.com/albums/y236/e78999/ | | |
