6 members (Charles in CA, lumbersawyer, Rustnut, Hotrod Lincoln, Donf, 1 invisible), 64 guests, and 4 robots.
Topics128,203
Posts1,057,414
Members48,471
This is what's installed in my 52 GMC 9430...not sure if this was the original (CDN built truck) or if this is an aftermarket GM product ?
Has anyone seen this type before or have any information ?
1952 GMC 9430 (Family owned since new)
Bumping this thread....again, has anyone seen this type of GM heater before ? It's installed on my 52 9434 one ton...pretty sure its a replacement unit. But it looks like it came from GM...Thanks
If it was rounder ...... it would look like the one in my '40 ....... which I believe was constructed for 1937 , you have similar door and knob structure , so may be a similar era .
Have you worked your way thru this thread ?
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=912753&page=all
General Motors passenger car heater from a early ‘40s late ‘30s Chevy Master. Also found some reference to early Buick’s.
Moderated by  ndkid275, Phak1
