6 members (Samantha, Hotrod Lincoln, mick53, 55shaker, 2-Ton, 1 invisible), 75 guests, and 3 robots.
Topics128,030
Posts1,055,424
Members48,422
#132717 07/13/2005 4:20 AM
i need help im a die hard chevy man and want to updatemy 1942 pickup with a 327 300hp and 5speed manual tranny late model chevy and change the frount end to rack and pinon stering and disk without using a mustang 2 frount end any help??IDEAS ????HELP!!!!!!!!!!!! :mad: :confused:
ya I know a few rednecks.Thay all drive chevys to,
Proud member of the Old Dominion Stovebolt Society
AND A MARINE
trucks range from 1942 1/2 ton to 1965 fire engine
#132718 07/13/2005 1:08 PM
Do you want to retain the exisiting suspension and add rack and pinion or do you want to replace it with IFS?
#132719 07/13/2005 6:19 PM
Junior Member
Junior Member
Check out Jim Carters website oldchevytrucks.com
they have a tech article to bolt in a AMC front clip.
I read it a while ago and if memory serves me the
whole front end bolts in with a simple adapter he sells.
Good luck.
#132720 07/14/2005 6:01 PM
i want ifs
AND A MARINE
#132721 07/14/2005 6:47 PM
Junior Member
Junior Member
It is IFS. complete, bolt in. The whole 9 yards. if you can find a Pacer, and a good column. Or a Flaming River job if you got that kinda dough.
#132722 07/14/2005 8:53 PM
I know that camaro/nova subframes will fit in the 47-55 AD trucks. The 42 will probably have different dimensions. It might be worth measuring one to see if the width is close. Another thought would be an S-10 frame.
I know the thought of putting ford parts in a chevy is horrible to some, but the the mustang II styled front ends will probably be the cleanest approach to get a good ride and decent handling. Most of the aftermarket front ends are based on the mustang II design but hardly use any ford parts. Take a look at fatman or tci suspension setups.
#132723 07/15/2005 3:13 PM
http://www.jimmeyerracing.com/adjustability.html
these have a fully adjustable front end
Jim & Caroline
#132724 07/15/2005 3:51 PM
1970's to 1987 GM pickup front ends bolt in with minmal mods.
#132725 07/19/2005 8:58 PM
If your looking for an aftermarket unit for about $2K, Scotts' Hot Rods in Ventura, CA has one of the best and cleanest installs. It's a single weld in crossmember (incl. spring hat and shock towers. No notching of the frame rails or boxing the frame is required. Each one is custom made to the dimensions of you specific truck/car.
#132726 07/21/2005 8:21 PM
Junior Member
Junior Member
use a pacer front end if you can find one. parts are cheap and easily found. the kit to put it in is about 100 bucks. mines power, and drives like a dream
#132727 07/25/2005 3:05 AM
Anonymous
Unregistered
Anonymous
Unregistered
Forget the pacer. Too hard to find a V8 model to use. You can do a clip if you like but the camaro subframe will be a bit too wide if you plan to drop it any from the stock height. The GM truck subframe is much too wide and looks goofy. If you are doing a serious re-build choose a IFS kit from the wide assortment. I did a subframe clip (see my pictures) it is very labor intensive. If you do not have the fab skills it is tough. The IFS kits are just so much easier.
#132728 08/05/2005 7:37 PM
Junior Member
Junior Member
hey huston, never seen or heard of a v-8 front end on a pacer. they all use ford brakes and saginaw r&p units. all this rebuilt or new for under 700 bucks.
#132729 08/05/2005 7:43 PM
Anonymous
Unregistered
Anonymous
Unregistered
Sorry I should have said V6. The 4 cylinder setup is too light to use. This is from second hand experience so your experience may differ.
#132730 08/05/2005 8:28 PM
The later gm truck front end works fine but you have to cut a cuple inches out of center crossmember,
If its done right it can look pretty good
if you know a good welder fabricater you can make almost anything work and look nice
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#132731 08/05/2005 8:49 PM
DJ Offline
On your 42 dont even think about the other stuff. Just buy the IFS kit. There is nothing in the kit that is F O R D so dont be worried. With the way your fenders are any clip or crossmember from a factory car is going to be a big mistake. TCI and proggresive makes a nice one for your truck. The gm crossmember narrowed has a lot of problems and does not even fit the ADs
Save up and do it one time. Pacer stuff is gone and worn out .Racks can be very hard to find and expensive. They dont look very good on the 42. If no money put discs on your stock axle for now.
#132732 08/05/2005 10:35 PM
Yup, depends on dosh. DJ's right, the ultimate must be a setup from specialists like TCI and Progressive.
On the other foot, I don't know about the fit on your 42 but the Pacer went on my 54 with no cutting and it's sweet. They're still out there in the boneyards. Autozone etc. do the AMC racks--about $100 with a core. They steer real well. If the springs on the clip are shot Eaton etc. do replacements. The brakes are great. And it all feels really robust.
But if as DJ says it would spoil the look of your 42, I'd at least follow his advice about discs. (Even though the great Italian racer Nuvolari shrugged off a question about finishing some race without any brakes with: "Who needs em, they only slow you down.")
Christian
