| | | Forums66 Topics128,152 Posts1,057,011 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | Here's a combination you may never have heard of. I acquired a Buick 350 with a 4L60E tranny awhile back for a thousand bucks. Out of a 1995 Roadmaster with 118,000 miles. The only reason I bought the set was the car had really been taken good care of until it went into a ditch! I'm thinking about putting this in my 1950 Chevy 3100 nice ratrod, not so nice streetrod. Any opinions as to ok idea or not? Unforeseen problems I might run into? | | | | | Joined: Jul 2019 Posts: 24 New Guy | | New Guy Joined: Jul 2019 Posts: 24 | Somebody did a bunch of work adapting that Buick 350 to the 4L60E and to get it injected (as a 95 should have been). If it was the stock engine from that wagon it wasn't a Buick. Buick 350 production ended in 1980. Pic of what they have for adapters would be cool.
Chris
Too many to work on 4 bolts, 2 square bodies, 4 GMT400s...and those are the keepers
| | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | A 95 Roadmaster would have had a 5.7 LT1 Chevy engine. A 4L60E transmission would also be part of that combination. You will likely need the wiring, computer, and related components to install it a different vehicle. Fred
| | | | | Joined: Sep 2019 Posts: 223 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 223 | I got all the related components with the purchase. I will have to purchase new wiring and some components when I install it in my truck...bypass some original setup, "tell the engine" what I need. I know I will probably be looking at somewhere between $500 and $1000 to have this custom made. | | |
