2 members (KEVINSKI, 1 invisible), 105 guests, and 1 robot.
Topics128,034
Posts1,055,552
#1326643 09/18/2019 11:10 AM
I want to put a master cylinder that came with my S10 frame on my 49 . Has anyone done this ? looking for location and what to use behind firewall ?
There are two routes to take for a firewall mount mc on an AD truck. The factory used a bracket that gave extra thickness to the firewall plus it extended to the lower bottom of the dash. This is the best set up if using manual brakes. If power brakes then there is much less pedal pressure to flex the firewall and an 1/8" plate on the inside of the firewall that runs from toe board angle on the bottom to pinch weld on the top is sufficient. Don't go thicker than 1/8 because the booster bracket bolts are pretty darn short. The one in the photo has the plate on the inside of the firewall.
[img]https://i.postimg.cc/tsfJ0HjF/S10-045.jpg[/img]
Evan
Thanks, Evan, I'm trying to lay out the firewall for the hole pattern . Do you have a picture of the under dash setup?
