| | | Forums66 Topics128,034 Posts1,055,539 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | I want to put a master cylinder that came with my S10 frame on my 49 . Has anyone done this ? looking for location and what to use behind firewall ? | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | There are two routes to take for a firewall mount mc on an AD truck. The factory used a bracket that gave extra thickness to the firewall plus it extended to the lower bottom of the dash. This is the best set up if using manual brakes. If power brakes then there is much less pedal pressure to flex the firewall and an 1/8" plate on the inside of the firewall that runs from toe board angle on the bottom to pinch weld on the top is sufficient. Don't go thicker than 1/8 because the booster bracket bolts are pretty darn short. The one in the photo has the plate on the inside of the firewall. [img]https://i.postimg.cc/tsfJ0HjF/S10-045.jpg[/img]
Evan
| | | | | Joined: Mar 2017 Posts: 25 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 25 | Thanks, Evan, I'm trying to lay out the firewall for the hole pattern . Do you have a picture of the under dash setup? | | |
