Brrrr
place holder
1 members (Peggy M), 134 guests, and 3 robots.
Topics128,271
Posts1,058,414
Members48,485
#1326640 09/18/2019 10:48 AM
I need some help with my power brake system.
From the looks of it I need to replace most of the parts. I would like to upgrade to a modern master cylinder, with front and rear independent circuits.
I have searched Stovebolt and a couple other forums for a bolt in power brake system for Drum/Drum. I am sure someone out there has made this
upgrade, maybe even knows the part numbers used.
Has anyone had any luck sourcing an under cab master cylinder that works with the 6 wheel cylinder, 2 ton trucks?
Thanks in advance
3B Offline
Hy RmJr, welcome, I have never seen a conversion kit from single system master to dual circuit master advertised for your size of truck. You have two basic choices a vacuum boosted system or a hydraulically boosted system, the hydraulically boosted system would require the installation of a power steering pump. I recommend using a dual master cylinder which has the same size bore as your original system, certainly not any smaller on the bore. You will probably have to piece together you own kit, just make sure everyone is aware these parts are for a drum/drum system. Good luck and don't be afraid to come back and ask more questions.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/topics/1089476/1.html
This guy has installed a dual master/booster on his 2 ton. I think it was part of a front disc brake kit put together by 'RDomeck' so the master would be a drum/disc.
I tried to get one of them to cough up part numbers with no luck. Seems as though when it comes to making money with a kit part numbers are not something that is shared !?!
Crusing in the Passing Lane
I seem to recall there is a late '80's Corvette drum/drum MC that could be used with any booster.
Ed
Big Bolt Forum Moderator
Ed
Maybe for a 1/2 ton but not for a 2 ton, it would not have a big enough bore to push that much fluid.
Mike
Noonan, If you knew the amount of time I have invested in making this kit work for these big old trucks you might understand that I am not making very much money on these kits. I have had a couple of guys run my master bracket with the modern dual circuit vacuum boosted master with success. I have not personally driven a drum brake truck with that set up, but As I understand, it works well.
On the kits, I am about a week away from having 5 kits put together for sale.
Randy Domeck
Indianapolis Fabrications
[email protected]
Indianapolis, In. 46254
317-258-0039
7
7 Offline
Vette's have been disc/disc since '63, unless that m/c was an aftermarket special setup.
Hi RDomeck,
I understand the work/time that you must have spent on this.
I PMed you earlier, I think we should talk.
Does anyone know the MC volume required to push 6 wheel cylinders?
'63 Vettes were drum/drum. A friend has one that he's converting to disc.
1965 was the first year for disc brakes on a Vette...now back to trucks, the 6400 would have a 1-1/4" bore MC.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thank you MikeB
