3 members (RLB, Oswald, GRNHydra), 86 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#13266 11/12/2002 5:40 AM
Junior Member
Junior Member
1 Offline
After many years of service, my spider gears on the differential are beginning to chip. I am not aware of anyone making replacement gears. So, it looks as if I need to scout out the wrecking yards for good replacement gears. What range of years are interchangeable for spider gears on a 1956 Chevy ½ ton? My best guess is 1955-1962. Does anyone know if this correct?
I really do not want to do a rear end swap since the brakes, 3.38 ring and pinion and bearings are in excellent condition.
1956Chevy3100
#13267 11/13/2002 12:58 PM
Try this link. www.tomsdifferentials.com/cat126.htm
It seems late 12 bolt spiders fit right in but you'll need modified 12 bolt axles. However, there are at least 2 different types of side gears and I'm not sure which carrier will fit the 12 bolt ones. I replaced the drop out in my '55 1st series with an early '60's 3.38 and the side gears were different. I had to mix and match the parts a bit. I hope this helps.
#13268 11/14/2002 6:20 AM
Junior Member
Junior Member
1 Offline
Kiwi Mike,
Thanks for the information. I will give Tom’s differential a call for more information. It looks as if it is a viable option. So far, I have found a 58 and 55 in the local wrecking yards; unfortunately, the spider gears were in worse condition than mine were.
Thanks for the good idea.
1956Chevy3100
